Rough ride
Posted: Thu Jan 07, 2010 4:17 am
by bigdaddyjosh
I have a bone stock 09Vibe 2.4. Why is the ride so rough. I feel every bump and divit in the road. Also there is a noticable clunk coming from the liftgate area when going over some bumps.
Re: Rough ride (bigdaddyjosh)
Posted: Thu Jan 07, 2010 4:50 am
by JetBlack09VibeGT
You might want to check to see if the spare tire and or jack is tightened down. Vibe suspension is inherently stiff, so keep in mind, if you're going to move to a larger diameter wheel, the ride will become more harsh.
Posted: Thu Jan 07, 2010 9:13 am
by star_deceiver
The rough ride is normal.That clunk is caused by the tailpipe hitting the rear bumper. Here's where it normally sits.It can move up pretty easily with a big enough bump...
Posted: Thu Feb 04, 2010 11:46 am
by B14CK_H4WK
whats your tire pressure?
Posted: Thu Feb 04, 2010 12:41 pm
by ponta2147
I noticed that as well but chalked it up to being just a stiff ride overall, plus needing some time to be broken in. It's starting to loosen up a bit.
Posted: Fri Feb 05, 2010 6:29 am
by Kincaid
Maybe it's what you're used to? My '09 2.4L doesn't feel hard at all - it soaks up those large speed bump things and glides over railroad crossings. Of course, the pavement might be smoother out here is well. We get little in the way of potholes and frost heaves.
