Any photos of 2009 1.8 with 02-07 16" Alloy Rims?
Posted: Wed Dec 09, 2009 9:42 am
by DocDoug
I am considering a set of 2005 16" alloy rims for my 2009 black 1.8 Vibe. I haven't seen a photo with combination.Thanks
Re: Any photos of 2009 1.8 with 02-07 16" Alloy Rims? (DocDoug)
Posted: Thu Dec 10, 2009 11:32 pm
by vibolista
I haven't. Have you found a set of first gen Vibe alloys for your car? Will fit fine... but take a look at TireRack on line to see a choice of 16 inch alloys. Plus you can view their alloys on an 09 Vibe.
Re: Any photos of 2009 1.8 with 02-07 16" Alloy Rims? (vibolista)
Posted: Fri Dec 11, 2009 1:36 pm
by DocDoug
Yes, purchased the 16" 1st gen and they are on their way. If only I can get a straight answer regarding not using the tire pressure monitors and if this affects the ABS and traction control.
Posted: Fri Dec 11, 2009 1:58 pm
by ou.grizzly
Quote, originally posted by DocDoug »Yes, purchased the 16" 1st gen and they are on their way. If only I can get a straight answer regarding not using the tire pressure monitors and if this affects the ABS and traction control. You will be fine without the sensors. I am not running the TPMS in one of my Vibe's. Traction Control and ABS will work properly. A light will be displayed on your dash cluster though.
