Brake squeaking when in park???
Posted: Wed Oct 07, 2009 6:29 am
by cptnsolo77
Was sitting in a parking spot ( car off & parked ) I noticed when I pressed the brakes would hear a squeak. Also when i pulled on the parking brake I got the same sound. Does my parking brake need to be lubed?
Re: Brake squeaking when in park??? (cptnsolo77)
Posted: Wed Oct 07, 2009 8:59 am
by lovemyraffe
You need to take the mouse out of your brakes. This was the cause of a squeaky brake syndrome of mine a few years back. GRAPHIC CONTENT CONTINUES BELOW...A mouse had somehow got its head stuck between the brake pad and the rotor. Needless to say, the mouse was dead and didn't have a head ("No more rhyming and I mean it!"). Once I removed the mouse, no more squeaking.
Re: Brake squeaking when in park??? (lovemyraffe)
Posted: Wed Oct 07, 2009 8:35 pm
by Whelan
I know that there is a noise when pressing the brake pedal in Park and releasing. But to me it sounds normal like the vacuum pump or pressure from the caliper pistons.
Posted: Wed Oct 07, 2009 11:18 pm
by Sublimewind
It's just the rear brake shows sliding on the backing plate.. shouldn't need to worry, but if you are, do a brake jerb..
Re: (Sublimewind)
Posted: Thu Oct 08, 2009 9:05 pm
by Whelan
Dey Tuuk ur Jubbs!
Re: (Whelan)
Posted: Fri Oct 09, 2009 12:01 am
by Sublimewind
Quote, originally posted by Whelan »Dey Tuuk ur Jubbs!You caught it...cool
Posted: Tue Nov 03, 2009 10:22 pm
by crug75hid
i think whatever the reason may be, you need to get your brakes fluids check. and lubrication of the hardware is a later purpose. be safe
