Wiper Blade Angle Adjustment
Posted: Mon May 19, 2003 12:48 pm
by KSNeptune
I noticed today that when my front wipers are off, the passenger side one doesn't move completely off the clear glass like the driver's side one does. There was plenty of room for it, but apparently whomever installed them didn't take the time to make the left match the right.Deciding I'd see if I could adjust them myself, I pulled off the black plastic piece covering a hex nut at the base of the passenger side wiper. Found a socket that would fit that nut, and loosened it about 1/2 a turn. Sure enough, the wiper stalk could then be rotated. I rotated mine down into the "black", to match the driver's side blade. Then tightened up the nut.Looks far better now. Still works perfectly. In fact now the passenger side blade wipes EXACTLY to the limit of the driver's blade arc. Before the paths were overlapping (too) much more.So check your wiper blades. If they don't both park below the clear glass, they can be adjusted easily. If adjusting the driver's side, you'll have to open the hood to access the nut.KSNeptune
Re: Wiper Blade Angle Adjustment (KSNeptune)
Posted: Wed May 21, 2003 12:06 pm
by pmh013
You know, I noticed the same thing the other day. Glad that this can be adjusted. I actually have a mechanical limit switch with the same type of locking mechanism that I work with, so I feel 100% on messing with it.Good project for the weekend.
Re: Wiper Blade Angle Adjustment (pmh013)
Posted: Thu May 22, 2003 2:27 am
by KSNeptune
quote:Good project for the weekend.Or at least for 5 minutes. That's all the time it took me. You might want to plan a few more things to occupy your weekend. KSNeptune
Re: Wiper Blade Angle Adjustment (silverawd26)
Posted: Thu May 22, 2003 6:29 am
by pmh013
I like Salsa's approach ... I don't need to drive it to see how it works. I have a few other things to do this weekend: plant garden, spray weeds, laundry, groceries.Man, I think I'll need Friday off!!
Posted: Sat May 24, 2003 7:37 am
by pmh013
Just got finished adjusting my passenger's side blade. I didn't move it much ... you can see the old position from the dirt line ... don't mind all the dead bugs on my windshield.Over all, definitely only a 5 minute procedure. I would recommend that you lift the hood to do it, you get much better access to the area. I only own a 14 mm socket, not a wrench, so I definitely needed the head room.No beer needed Now, back to that laundry.
Posted: Sat May 24, 2003 8:22 am
by Vibe
Looks much better-----NOW after your laundry--wash that VIBE!!! LOL!!
Posted: Thu Jul 24, 2003 11:59 am
by Toasted7
Wow... what a difference that makes in the way the Vibe looks. Now I don't have to look over to the passenger side windshield and get mad every time I see that d@$n wiper blade sticking up!!! Took me long enough to get around to do it and only took about 5 mins at most and worth every second of it!
Posted: Fri Jul 25, 2003 11:16 am
by Toasted7
I dont' know if that is worth it to add that to my signature or not. Probably not a big enough mod to worry about, but it sure does look better now! I'm thinking of getting white wiper blades to go with my Frosty Vibe... any thoughts on that? It my look too cheesy, but I'm not sure.
Posted: Sat Jul 26, 2003 11:02 am
by Toasted7
... you are the kidder!
Posted: Mon Jun 14, 2004 12:11 am
Has anyone checked the 04's and 05's to see how the wiper angle is?
Re: Wiper Blade Angle Adjustment (joatmon)
Posted: Mon Jun 14, 2004 11:17 am
by noginsk
Quote, originally posted by joatmon »Has anyone checked the 04's and 05's to see how the wiper angle is?Planning on checking my 04 when the sun is up in the morning
Re: Wiper Blade Angle Adjustment (noginsk)
Posted: Tue Jun 15, 2004 4:43 am
by noginsk
Yup, the blades on my 04 were just fine
