Wiper Blade Angle Adjustment
KSNeptune
Post by KSNeptune »
I noticed today that when my front wipers are off, the passenger side one doesn't move completely off the clear glass like the driver's side one does. There was plenty of room for it, but apparently whomever installed them didn't take the time to make the left match the right.Deciding I'd see if I could adjust them myself, I pulled off the black plastic piece covering a hex nut at the base of the passenger side wiper. Found a socket that would fit that nut, and loosened it about 1/2 a turn. Sure enough, the wiper stalk could then be rotated. I rotated mine down into the "black", to match the driver's side blade. Then tightened up the nut.Looks far better now. Still works perfectly. In fact now the passenger side blade wipes EXACTLY to the limit of the driver's blade arc. Before the paths were overlapping (too) much more.So check your wiper blades. If they don't both park below the clear glass, they can be adjusted easily. If adjusting the driver's side, you'll have to open the hood to access the nut.KSNeptune
pmh013
Re: Wiper Blade Angle Adjustment (KSNeptune)
Post by pmh013 »
You know, I noticed the same thing the other day. Glad that this can be adjusted. I actually have a mechanical limit switch with the same type of locking mechanism that I work with, so I feel 100% on messing with it.Good project for the weekend.
KSNeptune
Re: Wiper Blade Angle Adjustment (pmh013)
Post by KSNeptune »
quote:Good project for the weekend.Or at least for 5 minutes. That's all the time it took me. You might want to plan a few more things to occupy your weekend. KSNeptune
pmh013
Re: Wiper Blade Angle Adjustment (silverawd26)
Post by pmh013 »
I like Salsa's approach ... I don't need to drive it to see how it works. I have a few other things to do this weekend: plant garden, spray weeds, laundry, groceries.Man, I think I'll need Friday off!!
pmh013
Post by pmh013 »
Just got finished adjusting my passenger's side blade. I didn't move it much ... you can see the old position from the dirt line ... don't mind all the dead bugs on my windshield.Over all, definitely only a 5 minute procedure. I would recommend that you lift the hood to do it, you get much better access to the area. I only own a 14 mm socket, not a wrench, so I definitely needed the head room.No beer needed Now, back to that laundry.
Vibe
Post by Vibe »
Looks much better-----NOW after your laundry--wash that VIBE!!! LOL!!
Toasted7
Post by Toasted7 »
Wow... what a difference that makes in the way the Vibe looks. Now I don't have to look over to the passenger side windshield and get mad every time I see that d@$n wiper blade sticking up!!! Took me long enough to get around to do it and only took about 5 mins at most and worth every second of it!
Toasted7
Post by Toasted7 »
I dont' know if that is worth it to add that to my signature or not. Probably not a big enough mod to worry about, but it sure does look better now! I'm thinking of getting white wiper blades to go with my Frosty Vibe... any thoughts on that? It my look too cheesy, but I'm not sure.
Toasted7
Post by Toasted7 »
... you are the kidder!
Has anyone checked the 04's and 05's to see how the wiper angle is?
noginsk
Re: Wiper Blade Angle Adjustment (joatmon)
Post by noginsk »
Quote, originally posted by joatmon »Has anyone checked the 04's and 05's to see how the wiper angle is?Planning on checking my 04 when the sun is up in the morning
MattB.2004 Salsa base5 speedPower package NOW BELONGS TO EX-WIFE Looking at a new car, maybe a Scion tC or a Mazda 3 hatchback ------Give me a Vote on what you think I should get!: ----------- http://forums.genvibe.com/zerothread?id=11808
noginsk
Re: Wiper Blade Angle Adjustment (noginsk)
Post by noginsk »
Yup, the blades on my 04 were just fine
