Clicking when the car first starts when braking while in reverse and turning the wheel. (removed)?
Posted: Mon Sep 07, 2009 8:23 am
by headcold
There is a weird sound that happens about 80% of the time. Here's what to do to recreate the issue1. Turn the car on2. Reverse out of your parking spot, turning the wheel to position yourself towards exit3. Press the brake to slow down your idle reverse while still turning the wheel before you shift into Drive4. Hear "click-click, sometimes "clink-chunk", sometimes "chu-chunk"Most of the time this happens in reverse, but sometimes happens while I pull forwards out of a parking spot too. I only hear it when pulling out of parking sports, so it only happens in the first turn the car makes after being off for some period of time.Has anyone else heard this?
Posted: Mon Sep 07, 2009 9:27 am
by Sublimewind
That sounds like a CV joint..
Re: (Sublimewind)
Posted: Mon Sep 07, 2009 9:47 am
by lovemyraffe
Quote, originally posted by Sublimewind »That sounds like a CV joint.. +1
Posted: Tue Sep 08, 2009 6:11 am
by headcold
and that would be what? more importantly, if i take the car into a GM dealership for warranty service, will they know what i'm talking about and fix it for free?
Re: (headcold)
Posted: Tue Sep 08, 2009 8:50 am
by lovemyraffe
I'm not sure if the CV joints are covered by warranty or not.
Re: (lovemyraffe)
Posted: Wed Sep 09, 2009 12:13 am
by Kamikaze
I don't think CV, I think it's the same clunk most of us have when driving in reverse then going fwd:
http://forums.genvibe.com/zero...61357I've pretty much figured it's just a normal sound it does....
Re: (Kamikaze)
Posted: Wed Sep 09, 2009 10:57 pm
by Sublimewind
Quote, originally posted by Kamikaze »I don't think CV, I think it's the same clunk most of us have when driving in reverse then going fwd:
http://forums.genvibe.com/zero...61357I've pretty much figured it's just a normal sound it does....A single click or clunk maybe, but if it's a series of clicks when turning the wheel hard, or changing direction, it sounds like a CV joint... Headcold, the CV joints are part of the drive axles that run from the transmission to the front wheels...
