Cooling fan relay...
Posted: Tue Aug 11, 2009 8:50 pm
by danvin
Hi everyone.I got a problem this week-end with my cooling fan. Now, the only level working his HI ! I do not get any blowing for the first 3 levels of the fan. Air condionning is working, but also at HI level. I tried to switch 2 relay in the fuses box, nothing changed.What's the difference between relay FAN No.1 and relay FAN No.2? Do I have to change relay FAN No.2? (I switched FAN No.1 relay cause it seems to have a spare in the box, beside relay FAN No.2)By the way, I used a lot the interior outlet, like 2 hours at a time. Could that be the source of the problem?TanxDan
Posted: Tue Aug 11, 2009 8:55 pm
by bull77
welcome to genvibe sounds like a blower resistor issue -- fan will only work on high. sorta a common issue - it happened to me 2 years ago. http://forums.genvibe.com/zerothread?id=36099
Posted: Tue Aug 11, 2009 9:05 pm
by danvin
Thank you for your help.Could that be a fuse to replace instead of a relay or the blower itself?
Posted: Tue Aug 11, 2009 9:35 pm
by moonstonemike
Definately sounds like the resistor. Someone can correct me if I'm wrong but i believe there is only a fan relay for the electric fan that cools the radiator.
Re: (danvin)
Posted: Tue Aug 11, 2009 11:49 pm
Quote, originally posted by danvin »Thank you for your help.Could that be a fuse to replace instead of a relay or the blower itself?see the thread that bull77 posted the link for. If it runs on high, the blower, relay and fuse are all good. The resistor is an external separate item, and there is a growing number of vibes that have had it fail, with your exact symptoms.
