Catalytic Converter Lifespan and Diagnosis
Posted: Tue May 19, 2009 7:20 am
by Mojo72
I'm at 82K+ miles and am wondering when/if I need to start considering a catalytic converter replacement. What are some telltale signs?
Re: Catalytic Converter Lifespan and Diagnosis (Mojo72)
Posted: Tue May 19, 2009 8:34 am
by Caretaker
Geez, I'm at 115,000 and I haven't given it a thought. I don't replace anything until it breaks. Tell tale signs of a clogged Cat: your car doesn't start. My advice: carry a cell phone, check your tires weekly for spikes and nails, and ENJOY YOUR RIDE; it's a Corolla!!
Posted: Tue May 19, 2009 9:32 am
by zionzr2
Quote, originally posted by Mojo72 »I'm at 82K+ miles and am wondering when/if I need to start considering a catalytic converter replacement. What are some telltale signs?drop in fuel economy. foul odor (i.e. rotten eggs) Drop in performance. are signs to be aware of.
Re: Catalytic Converter Lifespan and Diagnosis (zionzr2)
Posted: Tue May 19, 2009 10:03 am
by ColonelPanic
What zionzr2 said plus check engine lights w/P0420's and such.None of those symptoms? Save your pennies and wait until they show up.
Re: Catalytic Converter Lifespan and Diagnosis (ColonelPanic)
Posted: Tue May 19, 2009 11:09 am
by Mojo72
Sounds like I'm good to go. Thanks for ALL of the great feedback!
Posted: Wed Jan 06, 2010 8:50 am
by alexod
118,010 miles, the Check engine light came on. Stopped by the repair shop, grinned grimaced and they read the code for me.Getting a new Cat next week(2004 auto, FWD, mostly freeway commute driving)
Re: Catalytic Converter Lifespan and Diagnosis (alexod)
Posted: Fri Jan 08, 2010 3:08 am
by Mojo72
That sucks. How much are they charging you?
Posted: Mon Jan 11, 2010 1:51 am
by borquezmike
Got the rotten egg smell at 101,000. I went ahead and replaced the whole downpipe assembly myslef for 500.00, including oxygenh sensors. Funny though Pontiac wanted 500.00 and Toyota wanted 1000.00, go figure. Stick with good gas this problem is less likely to come up.
Re: Catalytic Converter Lifespan and Diagnosis (borquezmike)
Posted: Mon Jan 11, 2010 1:58 am
by msu90
Nice! Wish I had the know-how around my car to do it. How long and how difficult is it to do?
Posted: Mon Jan 11, 2010 7:54 am
by Mojo72
How often did you change your O2 sensor(s) before the catalytic converter went south? I've read where worn out O2 sensors can shorten the lifespan of catalytic converters.
Posted: Mon Jan 11, 2010 8:43 am
by 06pvibe
Next time, try this site: http://www.discountconverter.c...s.cfm$245.03 and the shipping is good. Used these guys when my wife's Saturn gave it up @ 135k ($168 for the Saturn.) Or simply buy a universal and have it installed by your favorite muffler shop... but don't forget a new 02 sensor along with it.
Posted: Mon Jan 11, 2010 9:33 am
by hskater26
im going on my second cat within 40k miles.
Re: (06pvibe)
Posted: Tue Jan 12, 2010 1:11 am
by borquezmike
In California you are required on 2002+ newer vehicles to have OEM conveters installed, no universal units are allowed. Now this may not be a issue if the smog guy doesn't look, but due to its design and location I would not suggest using an aftermaket converter. You should replace your O2 @ 100k, earlier if you drive your car hard.
Re: (borquezmike)
Posted: Wed Jan 13, 2010 7:21 am
by Mojo72
My upstream O2 sensor coded P0133 about 5 times last winter at around 80K miles so I replaced it in May09 with a Bosch exact fit sensor that's seems to be getting the job done. Unless it starts coding, I'll wait until 100K before replacing the downstream sensor.
