Best Oil Filter in Toronto, ON?
Posted: Fri May 15, 2009 6:21 am
by ihsn
Hi,I'm looking to do an oil change and replace the oil filter of my '05 Vibe. What is the best oil filter I can buy locally here in Toronto, Canada?Which would you recommend? I would appreciate some quick suggestions as I want to get this done over this weekend. Thanks.
Re: Best Oil Filter in Toronto, ON? (ihsn)
Posted: Fri May 15, 2009 6:30 am
by zionzr2
the Purolator PureOne is the brand and type i use. part# PL 14476 you can also use PL 1447. the second is a slightly longer filter used in the GT models but they are interchangeable
Posted: Fri May 15, 2009 6:47 am
by ihsn
Is it available in Canadian Tire, Part Source?
Re: (ihsn)
Posted: Fri May 15, 2009 8:24 am
by zionzr2
While I do not know for sure as I'm not Canadian, but I do not see why not. you should be able to order them online from any number of places.I have ordered Oil and filters from Amazon even.
Posted: Fri May 15, 2009 10:00 pm
by moonstonemike
I usually go buy toyota filters at a toyota dealer. I can't remember the exact price but it was only like 4-5 bucks each and I usually pick up 5 or 6. Dont go to a gm dealer they will sell you the same filter for like 10 bucks each.
Re: (moonstonemike)
Posted: Sat May 16, 2009 12:28 am
by Herb
Quote, originally posted by moonstonemike »I usually go buy toyota filters at a toyota dealer. I can't remember the exact price but it was only like 4-5 bucks each and I usually pick up 5 or 6. Dont go to a gm dealer they will sell you the same filter for like 10 bucks each.I've done the same. They give you a break on price if you buy 4 or more
Re: (ihsn)
Posted: Sun May 17, 2009 1:27 am
by Silversn95
Quote, originally posted by ihsn »Is it available in Canadian Tire, Part Source?Not that I've seen. Canadian Tire and Part Source (same company) don't carry the good stuff when it comes to filters. You can try Napa (carries Wix, also a good filter) or as already has been mentioned, a Toyota dealer (this is were I get my filters).
