taillight fuse keeps blowing! need help?
Posted: Fri May 08, 2009 12:19 am
by vibe11
the brake lights will work but the fuse to my taillights keeps blowing any sugggestions
Posted: Fri May 08, 2009 7:55 am
by Paragon
Make sure you are using the proper size fuze.If it keeps blowing, there is a short somewhere or something is causing it to draw too much current.Did you change the bulbs or something?
Posted: Fri May 08, 2009 11:51 am
by audiovibe
Does the fuse blow the minute the car is turned on or at night when the lights turn on? Where is your remote wire and power wire ran?
Re: (audiovibe)
Posted: Wed Jul 22, 2009 4:19 am
by ewakko
I'm having this same problem. I replaced the fuse, pulled into the garage to check it and it was fine. The next time I went out at night, it was blown again.
Posted: Wed Jul 22, 2009 6:10 am
by Sublimewind
a short somewhere.. have either of the cars been modded in any way? panels removed/replaced for say an audio system?I would say a pinched wire..
