CEL P0442 Code
Posted: Fri May 01, 2009 2:53 am
by 2003blackGT
Looking for help with a check engine light code P0442.The description item for the code is “Evaporative Emission Control System Leak detected (small leak)” Any thoughts on where to start? Notes about my Vibe: 2003 GT, 97,500 miles, completely stock, original owner. I have seen no issues with performance, etc. Could the code come from a bad gas cap not keeping pressure? Also, where would the evaporation canister be located on the car to check for loose or disconnected line?Thanks in advance.
Re: CEL P0442 Code (2003blackGT)
Posted: Fri May 01, 2009 7:40 am
by Raven
Could be the gas cap. The evap can is under the rear end of the car on the driver's side I believe. Black rectangular box about 7x4x3 inches.
