HELP! Peripheral iPod Interface
Posted: Tue Mar 24, 2009 10:40 am
by lovemyraffe
I am now officially sick of having my cheap-@$$ stock stereo not play CD's for who knows what reason. After talking with a few local shops about Peripheral, I've come to a few conclusions.1. This is the best one for the money2. I can just buy this and install it myself3. I must buy an adapter to install it to my stock radio4. I cannot install it myself or I risk destroying the entire universe5. Nobody nearby can give me a straight answerCan anyone tell me which kit I need and whether or not I need an adapter to disable the thing-a-ma-jig hiding under the drivers seat?
Posted: Tue Mar 24, 2009 12:07 pm
by ClunkClunk
Which Peripheral iPod kit were you considering? Which headunit does your Vibe have?
Re: (ClunkClunk)
Posted: Tue Mar 24, 2009 12:11 pm
by lovemyraffe
I wish I knew which Peripheral kit I was looking at. My Vibe has the stock h-u, no moon & tunes.
Posted: Wed Mar 25, 2009 10:10 am
by lovemyraffe
Can anyone help me with this?
Re: (lovemyraffe)
Posted: Wed Mar 25, 2009 8:44 pm
by djkeev
Quote, originally posted by lovemyraffe »Can anyone help me with this?I think we could but we really need to understand what you are asking for. I'm sure your question makes perfect sense to you but you may indeed be the only one it makes sense to.You want to put in an aftermarket stereo head?You want to hook an iPod up to your factory radio?You want an afermarket head with iPod capabilities?What's under your seat?????????? Is this a guessing game?Have you already looked as a particular audio item and want others opinions on if its a good thing or not?I for one, haven't a clue what you want to do except you desire put in an iPod adapter somehow. Tell us specifically what you want when all is said and done.Dave
Posted: Wed Mar 25, 2009 11:29 pm
by Silverado Man
What you are probably wanting is to get the iPod2car. If you do a search on that you can find alot of information. I just installed this last summer and my wife uses it more than the radio. I found how to's and other great info.
http://forums.genvibe.com/zerothread?id=26800There is also a thread on what will work for what set up you have.
Re: (Silverado Man)
Posted: Thu Mar 26, 2009 4:48 am
by kevera
You should buy my iCruize.For the price you can't go wrong.If you pay for shipping it yours.
Re: HELP! Peripheral iPod Interface (lovemyraffe)
Posted: Tue Apr 07, 2009 12:26 pm
by audiovibe
Quote, originally posted by lovemyraffe »I am now officially sick of having my cheap-@$$ stock stereo not play CD's for who knows what reason. After talking with a few local shops about Peripheral, I've come to a few conclusions.1. This is the best one for the money2. I can just buy this and install it myself3. I must buy an adapter to install it to my stock radio4. I cannot install it myself or I risk destroying the entire universe5. Nobody nearby can give me a straight answerCan anyone tell me which kit I need and whether or not I need an adapter to disable the thing-a-ma-jig hiding under the drivers seat?
http://www.peripheralelectronics.com/For the 03-05 vibe you would need the ISGM73This kit comes with your harness all that is required is to hook up a constant and a negative wire, plug in to the port on the back of the radio, and set the dip switches gravey, gravey job. All you have to do is make sure you have the cd/aux button and your golden.To answer your questions.1. Yes Peripheral makes an awesome piece and can be found for under $1002. You hsould have no problem installing it a plug, 2 wires and 2 dip switches.3. Peripherals new kits include the harness you need.4. only if you attach a bomb5. no corners.Sorry Im a few days late on this, hope it helps.Peripherals website says that it will only work with 03-05 not compatiable with 06-currentAron
Posted: Tue Apr 07, 2009 10:32 pm
by northvibe
I used this one on mine.1. mm I think it retailed for 100-120, so its not cheaper than a fm transmitter or the "diy audio one"2. yes the install was easy.3. no this comes with everything for the stock 1 disk4. its 2 plugs and 2 wires that get "screwed" or tapped in its easy5. Hmm maybe you should find a new neighbor? a genvibe one?! The ONLY issue I had with mine was that the "power" source I used was always on, I should of found the one that was on only when the HU was on. Because my ipod couldnt be left plugged in or it would stay charging even if the car was off. Otherwise it was good.
Re: (northvibe)
Posted: Wed Apr 08, 2009 4:19 am
by audiovibe
Quote, originally posted by northvibe »The ONLY issue I had with mine was that the "power" source I used was always on, I should of found the one that was on only when the HU was on. Because my ipod couldnt be left plugged in or it would stay charging even if the car was off. Otherwise it was good.All you have to do is switch the Yellow wire on the Ipod interface to a switched source like the ACC on the radio instead of constant, that way when you turn the car off no power is present on the line.Aron
Re: (audiovibe)
Posted: Wed Apr 08, 2009 5:04 am
by northvibe
Quote, originally posted by audiovibe »All you have to do is switch the Yellow wire on the Ipod interface to a switched source like the ACC on the radio instead of constant, that way when you turn the car off no power is present on the line.Aronyeah I know but directions said blue power wire and once it was done I was way to lazy to take the HU out and redo it. Like I said it was just a different power wire you have to tap.
Re: (northvibe)
Posted: Wed Apr 08, 2009 7:44 am
by audiovibe
Parnell, I must be going blind, you did say that and I somehow missed it. Why is it that after we do something and finish it we are to lazy to change it later on? Aron
