codes,codes==
Posted: Sat Feb 14, 2009 1:55 pm
2004 non-turbo,automatic transmission.fwd, 94,000 miles. "cel" shining bright. codes Po133 and Po171. engine running ok. cold start idles around 1750rpm,s. never in sub-zero temps as tsb inquires. tsb says dealer should recalibrate computer ???? mpg in city is usually 22 mpg.no problem observed except "cel" is on. question = can problem build up and leave driver stranded? broke down? also can cat converter be damaged with"too lean"code?? thanks for any advice. Jamesmetairie.
