Update! Blown Motor
Posted: Mon Jan 05, 2009 10:28 pm
by THE VIBERATOR
This must be a first in the Genvibe Forums but my motor is blown! And no, I didn't do anything stupid. It spun a rod bearing upon startup (after sitting for about 2 weeks). It was so young....71,812 miles. Looks like I'll either have a slight chance of getting it rebuilt or they will get a new engine in there. Either way, it died early, and I'm hoping I'm not so unlucky next time. *sigh*
Posted: Mon Jan 05, 2009 10:45 pm
by Nelson
Condolences. Good luck on the repair or replacement.hugs
Re: Update! Blown Motor (THE VIBERATOR)
by BlueCrush
OUCH! Sorry to hear, Joseph. Hopefully, it's not down for long.
Posted: Mon Jan 05, 2009 10:52 pm
by northvibe
Damnronjr blew a engine too :./ sad to hear, hope you get it going quickly.
Re: (northvibe)
Posted: Mon Jan 05, 2009 10:56 pm
by BlueCrush
Quote, originally posted by northvibe »Damnronjr blew a engine too :./ sad to hear, hope you get it going quickly.Jason had a Supercharger on his when it blew, though.
Re: (BlueCrush)
Posted: Tue Jan 06, 2009 12:13 am
by jake75
Of course - with an '03 no warranty coverage left. Two things that are supposed to last a long time - an engine, and a transmission. And owners understandably feel cheated if there is an early failure. But it is so rare that they fail that a manufacturer could probably offer a $75 option to cover those for say 10 years, 100,000 miles.Owners would be happy, and manufacturers would avoid their wrath and negative publicity.Just my 3 cents (inflation you know).
Posted: Tue Jan 06, 2009 1:01 am
by prathman
Quote, originally posted by THE VIBERATOR »This must be a first in the Genvibe Forums but my motor is blown! And no, I didn't do anything stupid. It spun a rod bearing upon startup (after sitting for about 2 weeks).Unfortunately this is far from the first. But I thought you recently reported that you had let the engine get way low on the oil level. That could have been a contributing factor.
Re: Update! Blown Motor (prathman)
Posted: Tue Jan 06, 2009 2:04 am
by NibCrom
This engine was not stock though, right?Hope you get it fixed!
Posted: Tue Jan 06, 2009 2:06 am
by ou.grizzly
A few of the previous GT failures were due to an oil pump failure caused by an Aftermarket Pulley, at least in the 2 situations that are well documented on here. One member in Michigan and another in Maryland?
Posted: Tue Jan 06, 2009 2:24 am
by djb383
Quote, originally posted by prathman »......................But I thought you recently reported that you had let the engine get way low on the oil level. That could have been a contributing factor.That's what I was thinking.
http://forums.genvibe.com/zerothread?id=36029The first time I read it, I was puzzled how you could tell it had 1 qt in it..........and I'm still puzzled.
Re: Update! Blown Motor (djb383)
Posted: Tue Jan 06, 2009 4:51 am
by THE VIBERATOR
Well you are right...but it wasnt even registering on the dipstick. Meaning I had around a quart. After pouring 2 more quarts into the car, the level made it to the minimum on the safety. One more quart would have brought it to the top. However, they say the bearing was spun sometime shortly before the engine gave out, meaning the knocking noise was a loose but not completely spun bearing. It finally gave way and broke while i was on my way to work. Not driving the car would have saved the engine completely, and it would have been an easy repair. Not much I can do at this point but hope the engine is repairable. If not, I'll get my mods back but it will be a while before i can put them on.
Posted: Tue Jan 06, 2009 8:46 am
by 03vibedriver
Sorry Man. Check here for a motor. car-part.com
Re: Update! Blown Motor (03vibedriver)
Posted: Tue Jan 06, 2009 12:43 pm
by THE VIBERATOR
No need....I have some good news. I'm entrusting my car with a guy my dad knows who's been in the business for 30+ years. They took a look at my car and told my dad they would REBUILD it, which puts a huge smile on my face! I'm so relieved. They said the crankshaft was the part that caused the engine to die....but I don't know any more details than that....oh they also said the inside of my engine looked just fine, so it was not beat up at all I will keep everyone informed on what happens!
Posted: Tue Jan 06, 2009 9:26 pm
by ned23
I take it that used engine parts are not easy to find.
Re: Update! Blown Motor (13Vibe03)
Posted: Wed Jan 07, 2009 4:53 am
by THE VIBERATOR
Quote, originally posted by 13Vibe03 »The crankshaft bearing surface (journal) will likely have to be resurfaced which will make it undersized. Then, oversized bearing caps will be used to make up the difference. If all the other clearances check out, you're good to go.Yes very true...they will have to do that if they say the car needs a new crankshaft. As long as the clearances are to spec, and everything else is fine, it looks like my engine will be back up and running. Quote, originally posted by ned23 »I take it that used engine parts are not easy to find. Unfortunately when it comes to a crankshaft, I would rather have it be new. But yes typically used engine parts are hard to find.
Posted: Wed Jan 07, 2009 5:32 am
by djb383
Do you know which bearing(s) spun..........crank main or rod??????
Posted: Wed Jan 07, 2009 12:01 pm
by THE VIBERATOR
No I'm not sure really...as of this point I know as much as they told my dad, but when I get the car back, I will have to ask them so I know exactly what happened. In the meantime, I've been driving my dad's Honda Odyssey. That's a fun vehicle
Re: (Nelson)
Posted: Sun Aug 30, 2009 10:16 am
by H20Hardcore
mine spun a crank berring @28k no warrenty would cover cost me over 4k to rebuild @least place I bought it from used supplied free labor though. prob from previous owner cuz I only had the car for roughly 11k mi when it happened. THATS TOOOO YOUNG!!!
