Timing belt change
Posted: Sun Dec 07, 2008 9:19 am
by VibeMike
Does anyone know the general mileage a timing belt should be changed? I am over 100,000 miles with my original belt and I figure I am overdue for this change. I understand it is better to change it before it breaks on you--Mister Obvious!!!
Re: Timing belt change (VibeMike)
Posted: Sun Dec 07, 2008 9:21 am
by Raven
The Vibe has a timing chain.
Posted: Sun Dec 07, 2008 10:11 am
by ColonelPanic
No maintenance ever needed! It takes a lot of miles to screw up the chain.
Posted: Mon Dec 08, 2008 5:25 am
by jtnovibe
Maybe he's referring to the serpentine belt? I didn't see anything in the owner's manual about when that should be changed.-JT
Re: (jtnovibe)
Posted: Mon Dec 08, 2008 5:42 am
by Raven
Quote, originally posted by jtnovibe »Maybe he's referring to the serpentine belt? I didn't see anything in the owner's manual about when that should be changed.-JTWhen it looks cracked or when it breaks, probably 100,000+ miles.
Re: (jtnovibe)
Posted: Mon Dec 08, 2008 5:45 am
by ColonelPanic
Yeah, they don't usually specify a service interval for drive belts... basically you just have to watch them and get them replaced when they become worn. If it is 100k on the original serpentine belt, do get that replaced...
Re: (ColonelPanic)
Posted: Mon Dec 08, 2008 9:44 am
by VibeMike
Yes I was referring to the timing belt/chain--I know some autos do have chains which last much longer--so I am glad the Vibes have chains not belts. However since I am over 100,000 on my original belts, I will have them checked soon. Thanks!
