2009 Fog Lamp Parts - $444 dealer retail
Posted: Fri Dec 05, 2008 1:30 am
by ned23
I got the dealer retail price for the OEM parts to add Fog Lamps to an '09 Vibe. Lamps, Relay, bulbs and Switch run $444 straight-up from dealer. Add $28 for GT lamps because of the different trim. The lamps plug in right where the delete plugs go. They're basically mounted in what looks like a delete plug with the center cut out. Most of that cost is dealer mark-up and if you call Pontiac and have them call your dealer they may be able to negotiate a discount on the parts.
Re: 2009 Fog Lamp Parts - $444 dealer retail (ned23)
Posted: Fri Dec 05, 2008 6:52 am
by shemp
wshew... that's expensive for stock lamps. IMHO PIAA makes some really nice stuff for much less:http://www.amazon.com/gp/product/B00067BUYC
Re: 2009 Fog Lamp Parts - $444 dealer retail (shemp)
Posted: Mon Dec 08, 2008 3:22 am
by ned23
It would be nice if you could install those in the same place on your bumper as the where the stock lamps go. The wiring is all already there and they won't protrude in such a way as to "attract" flying road debris.
Posted: Mon Dec 08, 2008 3:39 am
by shemp
Quote, originally posted by ned23 »It would be nice if you could install those in the same place on your bumper as the where the stock lamps go. What's stopping you? Also, I'm not aware of the force of nature that attracts road debris to fog lights, but it may be related to the wormhole that consumes single socks at random.
Posted: Mon Dec 08, 2008 3:41 am
by ned23
Quote, originally posted by shemp »What's stopping you? Also, I'm not aware of the force of nature that attracts road debris to fog lights, but it may be related to the wormhole that consumes single socks at random. They usually install them below the bumper, which in this case is much closer to the road. Half the reason I want them is to replace the black plugs in the bumper.
Posted: Mon Dec 08, 2008 4:00 am
by shemp
I don't know who "they" are, but I wouldn't hire them. I'd either put them on myself in the stock location, or hire "someone" who will put them in their proper spot.
Posted: Mon Dec 08, 2008 12:13 pm
by dzknmd1
Posted: Tue Dec 09, 2008 3:00 am
by ned23
Quote, originally posted by shemp »I don't know who "they" are, but I wouldn't hire them. I'd either put them on myself in the stock location, or hire "someone" who will put them in their proper spot.I suppose that's possible but I've looked at the bumper and it would be tricky. The inside of the bumper is enclosed with cover on the rear. There are not many places to attach a bracket inside of it. There's also the trick of sealing up the hole so the inside of the bumper doesn't fill up with stuff blown into it or get filled with snow and ice. Quote, originally posted by dzknmd1 »Try this:http://www.gmpartsdirect.comGood catch. I'll take a look. I know that salvage parts aren't available yet, and I've also been told that when you have an intact front-end, usually they want to sell the whole front-end to a body shop. I'm also still working with the dealers. I may be able to get the stock stuff installed for $300 or so.
