HIR lights
Posted: Mon Dec 01, 2008 2:01 pm
by jerzVibe09
This is a followup to an earlier posthttp://forums.genvibe.com/zerothread?id=35550I just installed the 9012 HIRPRICE: $52INSTALL: Easy. If you can get the stock bulbs out, thats the hardest part. (need small hands). Modifying the base of the HIR bulbs was easy, I used a dremel with a cut wheel. Took 5 minutes and I don't think I was overly precise. RESULTS: I don't notice a huge difference in the light output. I am not overly impressed. But I see an improvement. I drove home in the rain and didn't notice and refraction problems. See pics.CONCLUSION: If you need new headlights, these make a good replacement. If you want really bright upgraded lights, these aren't the solution.
Re: HIR lights (jerzVibe09)
Posted: Mon Dec 01, 2008 10:32 pm
by Whelan
I had HIRs in my car for months. I loved them! The output was definitely noticeable to me. I have since moved them into my Fog lamps since I upgraded to HIDs. Cost of those was $70. They won't give you the color that most people desire, but in terms of usefulness, I was able to see farther and wider. Light output is measured in Lumens. The low beam HIR outputs 1000 lumens versus a stock low beam at 7-800. Your stock high beam is approximately 1100 lumens and an HIR high beam is almost 1800. 9006 = 90129005 = 9011Many people use the 9011 bulb in their low beams to get that additional oomph. I gotta find my old post about the HIRs, it's here somewhere with pics.
Re: HIR lights (Whelan)
Posted: Tue Dec 02, 2008 2:19 am
by lowincash
yah the beam shines farther and wider than before and output was quite brighter than stock. they are definitely a good improvement over stock. of course these won't be as bright as HID's but i notice when driving down the street or fwy my car throws out more light than other halogen cars around me.
