Check Engine Light - P0171
Posted: Thu Nov 20, 2008 10:17 pm
by NibCrom
My CEL has been going on and off for the past week or so. It only seems to come on after I've parked it outside for a while. Occasional rough idle. Not sure I want to replace the oxygen sensor if that is not the problem. Thoughts?
Re: Check Engine Light - P0171 (NibCrom)
Posted: Thu Nov 20, 2008 10:20 pm
by BlueCrush
http://www.obd-codes.com/p0171It could be a vacuum leak or dirty MAF sensor. I would check all your hoses first and clean your MAF sensor before replacing the 02 sensor.
Re: Check Engine Light - P0171 (BlueCrush)
Posted: Thu Nov 20, 2008 11:10 pm
by NibCrom
How do I clean the MAF sensor and where is it located on the Vibe?
Posted: Thu Nov 20, 2008 11:23 pm
by bull77
very easy to findhttp://matrixowners.com/?showtopic=27838
Posted: Fri Nov 21, 2008 6:45 am
by Raven
Run a tank or two of Techron injector cleaner. Not STP, not Goldbloom and Finch, Techron only. In my 5 + years of Vibe ownership the injectors seem to be easily fouled and that code comes up on occassion. Now I just run a tank of Techron at each oil change.
Re: Check Engine Light - P0171 (Raven)
Posted: Tue Dec 09, 2008 10:29 pm
by NibCrom
Cleaned the MAF sensor. Check engine light is gone. Seems like a good fix for the P0171 cel code. Thanks guys!
Posted: Wed Dec 10, 2008 11:59 pm
by NibCrom
Well I spoke too soon. The light is back. I guess I'll try cleaning the MAF sensor again and then run some Techron, although in the past that stuff hasn't helped me any.
Posted: Wed Dec 31, 2008 2:28 am
by NibCrom
So far the Techron is actually working. I'll see if it lasts.
Posted: Wed Dec 31, 2008 4:39 am
by THE VIBERATOR
If the light comes back, try checking for a vacuum leak, seeing how you can only clean the MAF sensor so much before it actually does get clean. Or you could easily go to a dealer and have them diagnose it for you if you feel a bit nervous about the code.
Posted: Wed Dec 31, 2008 10:34 am
by trimovingxr
If CEL (P0171) comes on during subfreezing temps and accompanied by rough idle, problem could be leaking intake manifold gasket. Dealer should cover repairs under TSB...
http://toyota.justanswer.com/u...1.pdf
Re: Check Engine Light - P0171 (trimovingxr)
Posted: Thu Jan 01, 2009 2:20 am
by THE VIBERATOR
He'd better hope his car has less than 36,000 miles, otherwise they won't cover it....and an intake manifold gasket isnt bad...if it was the intake manifold itself then that would be something I'd wanna take care of immediately.
Posted: Fri Jan 16, 2009 1:49 am
by sdavis
