Check Engine Light - P0171
NibCrom
Post by NibCrom »
My CEL has been going on and off for the past week or so. It only seems to come on after I've parked it outside for a while. Occasional rough idle. Not sure I want to replace the oxygen sensor if that is not the problem. Thoughts?
BlueCrush
Re: Check Engine Light - P0171 (NibCrom)
Post by BlueCrush »
http://www.obd-codes.com/p0171It could be a vacuum leak or dirty MAF sensor. I would check all your hoses first and clean your MAF sensor before replacing the 02 sensor.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
NibCrom
Re: Check Engine Light - P0171 (BlueCrush)
Post by NibCrom »
How do I clean the MAF sensor and where is it located on the Vibe?
bull77
Post by bull77 »
very easy to findhttp://matrixowners.com/?showtopic=27838
Raven
Post by Raven »
Run a tank or two of Techron injector cleaner. Not STP, not Goldbloom and Finch, Techron only. In my 5 + years of Vibe ownership the injectors seem to be easily fouled and that code comes up on occassion. Now I just run a tank of Techron at each oil change.
NibCrom
Re: Check Engine Light - P0171 (Raven)
Post by NibCrom »
Cleaned the MAF sensor. Check engine light is gone. Seems like a good fix for the P0171 cel code. Thanks guys!
NibCrom
Post by NibCrom »
Well I spoke too soon. The light is back. I guess I'll try cleaning the MAF sensor again and then run some Techron, although in the past that stuff hasn't helped me any.
NibCrom
Post by NibCrom »
So far the Techron is actually working. I'll see if it lasts.
THE VIBERATOR
Post by THE VIBERATOR »
If the light comes back, try checking for a vacuum leak, seeing how you can only clean the MAF sensor so much before it actually does get clean. Or you could easily go to a dealer and have them diagnose it for you if you feel a bit nervous about the code.
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
trimovingxr
Post by trimovingxr »
If CEL (P0171) comes on during subfreezing temps and accompanied by rough idle, problem could be leaking intake manifold gasket. Dealer should cover repairs under TSB...http://toyota.justanswer.com/u...1.pdf
My Webpage
THE VIBERATOR
Re: Check Engine Light - P0171 (trimovingxr)
He'd better hope his car has less than 36,000 miles, otherwise they won't cover it....and an intake manifold gasket isnt bad...if it was the intake manifold itself then that would be something I'd wanna take care of immediately.
sdavis
Post by sdavis »
