03 and 05 vibe
Posted: Thu Oct 02, 2008 11:35 pm
by vibe11
is the o3 Pontiac vibe headlight assembly compatible with the 05 vibe headlight assembly?
Re: 03 and 05 vibe (vibe11)
Posted: Thu Oct 02, 2008 11:40 pm
by BlueCrush
Quote, originally posted by vibe11 »is the o3 Pontiac vibe headlight assembly compatible with the 05 vibe headlight assembly?I believe it is, but others should be able to confirm that. I considered swapping out my '05 headlights with a set of new '04s but they cost too dang much new and I would only want new if I were to replace them.
Re: 03 and 05 vibe (BlueCrush)
Posted: Thu Oct 02, 2008 11:46 pm
by vibe11
i hit a mailbox last year. it just ran out in front of me so now i have enough money saved up to fix it. i currently need a hood new or used. and a right passenger headlight assembly.
Posted: Thu Oct 02, 2008 11:58 pm
by BlueCrush
Well the '03-'04 headlights are black and chrome and the '05-'08 headights are all chrome. So unless you are wanting to switch out both headlights get the same as your left one.
Posted: Fri Oct 03, 2008 12:01 am
by vibe11
if i got two 05 headlight assemblies will it still mount up two the 03 brackets and bolt pattern?
Posted: Fri Oct 03, 2008 12:28 am
by vibe11
thanks for the info just saved me alot of money just ordered two right and left 06 headlight assemblies!!
