Plastic fastners/shop manual
Posted: Fri Sep 26, 2008 5:52 am
by Beemer
How do you release/remove the two plastic fastners that hold the rear of the plastic engine (head) cover without breaking them?Has anyone published an after market shop manual for a 2005 Vibe?
Re: Plastic fastners/shop manual (Beemer)
Posted: Fri Sep 26, 2008 6:18 am
by keithvibe
the clips your talking about are just pressed in... simple door trim removal tool takes care of those or a flat head scewdriverYou won't find a repair manual in the store. However you can down load the manual in PDF format from
http://www.Matrixowners.comGo the the main page on the center of the main page there is a link to down load the manual your talking about. The link will take you to
http://www.megaupload.comOnce there enter in the code in the center of the screen in the code box... wait 30 to 60 seconds and then the download will begin.
Posted: Fri Sep 26, 2008 12:06 pm
Quote, originally posted by Beemer »How do you release/remove the two plastic fastners that hold the rear of the plastic engine (head) cover without breaking them?The first time I took that ccover off I broke both of the plastic fasteners, and never replaced them. I forget that there used to be fasteners there.
