Reverse Lights
Posted: Fri Aug 29, 2008 8:00 am
by Envy03
Anyone have both reverse bulbs go out at the same time, pull them out only to see that they are both not blown?Where did you get your replacement bulbs? dealer?
Re: Reverse Lights (Envy03)
Posted: Fri Aug 29, 2008 8:05 am
by kunkstyle
Sounds like a bad switch. Although sometimes they can be blown and the filament still looks good.Any parts store should have bulbs. They're not a dealer specific item. The last set I got were from Canadian Tire.
Posted: Fri Aug 29, 2008 10:29 pm
I thought both of mine were blown, but it was the connector on the transmission that was not seated correctly and had worked itself loose
Re: Reverse Lights (kunkstyle)
Posted: Fri Aug 29, 2008 10:48 pm
by Herb
Quote, originally posted by kunkstyle »Sounds like a bad switch. Although sometimes they can be blown and the filament still looks good.Any parts store should have bulbs. They're not a dealer specific item. The last set I got were from Canadian Tire.I've had the same thing happen on an older car. There's a switch on the transmission that activates the reverse lights. Replacing this should do the trick
Posted: Tue Sep 02, 2008 4:56 am
by Envy03
this switch replacement, is it a DIY? if so how would I go about doing it?
