Warm spot on stering wheel cover
Posted: Tue Aug 12, 2008 9:55 am
by rdnzl
On my 09 I nitice that on the air bag "pouch" or whatever you call it, that is on the steering wheel, there is a spot on the left side that is warm when I drive.Why is that? Is is something to do with the air bag system?
Re: Warm spot on stering wheel cover (rdnzl)
Posted: Tue Aug 12, 2008 10:10 am
by drmc1983
I'm not quite sure, but i haven't noticed that on mine yet. On my way to work tomorrow i will check it out.Since we are on the topic of noticing things. Do you have an automatic? If so when you put it in manual does yours automatically start at gear 4 no matter what? I'm not sure if that is a problem or not, but it would seem that it should start at 1 at rest. Instead it is always at 4 unless i change it.
Posted: Tue Aug 12, 2008 10:16 am
by rdnzl
at rest its 1 IIRC.
Re: Warm spot on stering wheel cover (drmc1983)
Posted: Tue Aug 12, 2008 10:17 am
by nygiantzz1
Quote, originally posted by drmc1983 »I'm not quite sure, but i haven't noticed that on mine yet. On my way to work tomorrow i will check it out.Since we are on the topic of noticing things. Do you have an automatic? If so when you put it in manual does yours automatically start at gear 4 no matter what? I'm not sure if that is a problem or not, but it would seem that it should start at 1 at rest. Instead it is always at 4 unless i change it. Mine does the same, always defaults to 4.
Re: Warm spot on stering wheel cover (nygiantzz1)
Posted: Tue Aug 12, 2008 10:36 am
by drmc1983
Is that something to be concerned about?
Posted: Tue Aug 12, 2008 10:39 am
by cycleb
Were you parked in the sun, or running a heater?
Posted: Tue Aug 12, 2008 10:47 am
by rdnzl
Driving down the freeway with the AC on. I noticed that just to the right of the radio controls, the "pad" has a warm area.
Re: (rdnzl)
Posted: Tue Aug 12, 2008 10:53 am
by VforVIBE
Quote, originally posted by rdnzl »Driving down the freeway with the AC on. I noticed that just to the right of the radio controls, the "pad" has a warm area.Headlights on or off... it just might be the heat from lights of the controls... I'll check mine tomorrow.
Posted: Tue Aug 12, 2008 10:56 am
by rdnzl
Just DTR lights on.I noticed another small warm spot on the right side of the dash, by the passenger airbag. It must be a sensor or something.
