Auto door locks
Posted: Thu Aug 07, 2008 2:46 am
by willysr
I have a 2009 and has anyone tried to bypass the auto door lock feature so when it is put in gear all doors and back hatch will quit locking automaticly?
Re: Auto door locks (willysr)
Posted: Thu Aug 07, 2008 2:53 am
by VforVIBE
I think it can be programmed to do that, see the owners manual.
Posted: Thu Aug 07, 2008 10:15 am
by lowincash
just curious...why do you want to take out this feature? i actually like this feature...feels more safe and don't have to worry about someone carjacking you while you're driving...but that's when i drive in a very bad neighborhood haha
Re: (lowincash)
Posted: Thu Aug 07, 2008 8:43 pm
by moongdss
I changed mine from locking when i start the car to locking when I actually put it into Drive. And it now unlocks when I put it into park.
Re: (moongdss)
Posted: Sat Aug 09, 2008 4:04 am
by lowincash
that's how the 2009 ones are set up
door locks
Posted: Mon Aug 11, 2008 4:14 am
by willysr
can the auto locks be programmed not to lock when put in gear?09 2.4,5spd. auto.For some reason not all doors will unlock after putting in park??
Re: door locks (willysr)
Posted: Mon Aug 11, 2008 5:41 am
by VforVIBE
Quote, originally posted by willysr »can the auto locks be programmed not to lock when put in gear?Yes, look at your owners manual.Quote, originally posted by willysr »For some reason not all doors will unlock after putting in park??Which ones, could the child safety locks be on?
Posted: Wed Nov 18, 2009 2:41 am
by leemur
This is an old post but ...I never found this info in the 09 manual. It isn't in the 2-26 area or anywhere else that I saw. I have the directions for my 04 Vibe but can someone just post the proccess for the 09. My 09 only unlocks the doors after the car is shut off. You can't get into the front or rear doors. If you pull up to the school, put the car in park and wait for the kid...he walks up, grabs the handle and pulls and I have to say, "oh, hold on...don't keep yankin on the door!"Thanks greatly.
Posted: Wed Nov 18, 2009 2:43 am
by spiffy1001
Why don't you take your Vibe to the same body shop I took mine to after my wreck. They seemed to make it so that the hatch doesn't lock AT ALL any more. Oh, they will fix it as soon as I have a weekday that I don't need my car.
Posted: Wed Nov 18, 2009 4:20 am
by kowell
Quote, originally posted by willysr »can the auto locks be programmed not to lock when put in gear?09 2.4,5spd. auto.For some reason not all doors will unlock after putting in park??Correct me if I'm wrong but don't the doors unlock when the car is turned off?If you put the car in park but keep the engine running, the doors won't unlock on their own but you are still able to open the 2 front doors if you wish. The rear doors will remain locked until you turn off the ignition or unlock them manually.
Re: door locks (kowell)
Posted: Wed Nov 18, 2009 5:06 am
by jake75
My theory is that I'd rather have them stay locked and be bothered to unlock them when I consciously need to than to unlock automatically and get hijacked.
Posted: Wed Nov 18, 2009 6:28 am
by gimmegimme
The only setting I was able to change myself was whether the doors unlocked when turning the car off. Turn the key to ON, shift out of Park, press unlock on the door six times, then lock. The car will unlock/lock the doors to acknowledge that the setting was changed.I think everything else you need to have the dealer's fancy schmancy scan tool to configure.
Posted: Wed Nov 18, 2009 8:31 am
by 09vGT
Ok, so is the dealer needed to make the doors unlock when shifted into park.. My backseat passengers get very aggravated if they can't get out.. It locks when put into gear, but then won't UNlock until the car is turned OFF..
