Solved the buzzing noise...
Posted: Sun Apr 06, 2003 8:04 am
Like many of you, I've had the dreaded buzzing noise coming from my dashboard. It gets most extreme at 3000 - 4000 rpm. Anyway, after extensive searching, I believe I've got it licked.It seems to be coming from the glove box. When I removed it, I noticed the backside of the box is thin plastic, a prime area for vibrational noises. I decided to use a sound dampening material (Dynamat Extreme or FatMat Extreme) to isolate the noise.Voila! A nice sheet stuck to the backside of the box and the noise is gone. Did not see any other potential source, but checked all of the wiring harnesses to verify none would shake loose in the near future. So far, the noise is gone... Perhaps this was and is the dreaded source. In my case, it seems to be so.
