Have a vacuum leak
Posted: Sun May 18, 2008 5:43 am
by Petrucci914
Hey everyone,I have a vacuum leak somewhere. I hear a whistling sound when first giving it gas and my idle is very poor. I've checked every hose that I can see and haven't seen any cracks or anything. I noticed some moisture where the dipstick for the engine is......maybe the supercharger isn't sealed all the way? I'm not sure. Any hints on finding a vacuum leak? This may be responsible for lots of my issues and why I'm not hitting full boost.
Re: Have a vacuum leak (Petrucci914)
Posted: Mon May 19, 2008 12:01 am
by Petrucci914
Nothin?
Posted: Mon May 19, 2008 12:26 am
by RIT
One method is to spray a "carb cleaner: around the engine/hoses. When it gets sucked into the engine via the vacuum leak, the engine rpms should change to let you know that you are in the correct area to look closer.
Re: Have a vacuum leak (RIT)
Posted: Tue May 20, 2008 4:52 am
by Petrucci914
I don't know if I can do that, I'm supercharged - not supposed to spray carb cleaner or anything in/around the throttle body while running. Any other ideas? I just know this is the source of my problems......maybe the SC'er isnt bolted on tight enough.......who knows.
Posted: Tue May 20, 2008 5:31 am
by engineertwin2
Only way I've found vacuum leaks before is using the old stethoscope. But, admittedly, I have only had one real hard to find leak.
Posted: Tue May 20, 2008 6:03 am
by kevera
Did you use the copper stuff when you put on your s/c.(You sprayed both sides right)You can also check your TB gasket.Other wise you'll have to listen for leaks while raising rpms.
Posted: Tue May 20, 2008 6:04 am
by Sublimewind
Quote, originally posted by Petrucci914 »I don't know if I can do that, I'm supercharged - not supposed to spray carb cleaner or anything in/around the throttle body while running. Any other ideas? I just know this is the source of my problems......maybe the SC'er isnt bolted on tight enough.......who knows.Starting fluid insted...?? if you took it to a shop, they would hook the system up to a vacuum pump and pull(try) a vacuum on it and go from there...
Re: Have a vacuum leak (kevera)
Posted: Tue May 20, 2008 6:06 am
by Petrucci914
Quote, originally posted by kevera »Did you use the copper stuff when you put on your s/c.(You sprayed both sides right)You can also check your TB gasket.Other wise you'll have to listen for leaks while raising rpms. Ya, I used the copper spray-a-gasket. After I got my motor mount inserts installed it idled pretty bad and then I took off the TB and cleaned the IACV and it was good for a while. Now it's back. I'll be reinstalling the new TB this weekend and go from there. I know a shop in GB that uses the smoke machine for vacuum leaks, so I guess I'll go from there.
Posted: Mon Oct 04, 2010 12:01 pm
by epcIII
Quote, originally posted by Petrucci914 »Hey everyone,I have a vacuum leak somewhere. I hear a whistling sound when first giving it gas and my idle is very poor. I've checked every hose that I can see and haven't seen any cracks or anything. I noticed some moisture where the dipstick for the engine is......maybe the supercharger isn't sealed all the way? I'm not sure. Any hints on finding a vacuum leak? This may be responsible for lots of my issues and why I'm not hitting full boost.I think I'm having the same problem but couldn't find the leak either.
Re: Have a vacuum leak (epcIII)
Posted: Mon Oct 04, 2010 1:38 pm
by BlueCrush
Quote, originally posted by epcIII »I think I'm having the same problem but couldn't find the leak either. You have a supercharger , too?
Re: Have a vacuum leak (BlueCrush)
Posted: Fri Oct 08, 2010 12:12 pm
by epcIII
Quote, originally posted by BlueCrush »You have a supercharger , too?Oops! No I don't have supercharger but I also hearing some kind of 'hiss', esp. right before the engine revs when giving it gas.
