Hold Off Buying Towing Hitch for 2009 Vibe/Matrix
Posted: Tue May 13, 2008 10:51 pm
by agksimon
I received a Curt Hitch 12228 towing hitch after being told by their customer service that it would fit my 2009 AWD Vibe. I installed it, but the hitch was touching the muffler and at low rpm, made lots of noise. I called them and they said the AWD Vibes they tried them on had a half-inch of clearance, but they are going to redesign the hitch for more clearance. The current cross bar is 2 1/2" X 1 1/2" and the re-design will be closer to square, but heavier gauge stock. This should add an inch of room. They are going to ship me the new design next week (around May 21, 2008) for a try and then I'll ship the other one back to them on their dime.I'll keep you posted on how it works.
Re: Hold Off Buying Towing Hitch for 2009 Vibe/Matrix (agksimon)
Posted: Tue May 13, 2008 11:16 pm
by joholste
sounds like they've got pretty good customer service. Hey you should come down to the meet we're having in Tennesse on July 26 and 27th. There's a couple people coming down from that area.
2009 Vibe Towing Hitch
Posted: Thu May 15, 2008 8:46 am
by agksimon
I'll be tied up at that time, but I wish we had a local club in West Michigan.Curt Hitches come with a very heavy, shiny powder coating, not paint and look like they will hold up against rust very well.They really have a quality product.
Re: (agksimon)
Posted: Thu May 15, 2008 8:47 am
by BoostFrenzy
i'm in grandville
Posted: Wed May 21, 2008 6:52 am
by agksimon
Curt Hitches is shipping me out a re-designed hitch for my 2009 Vibe on May 23, 2008. This one is narrower front to back and should fit better without hitting the muffler.
Re: (agksimon)
Posted: Mon May 26, 2008 6:04 am
by Eloi
Please, let me know how it works, cause I have the same problem with a Hidden Hitch #60958 that I got installed on my 2009 Vibe 2.4L. It's hitting the muffler and to make it stop, the hitch dealer wants to change the muffler's original flexible supports for rigid ones, something I'm not too sure I wanna do...Thanks.
Posted: Sun Jun 08, 2008 9:53 pm
by Eloi
@agksimon:So, did you get your re-designed hitch? Is it fitting fine now?
Posted: Tue May 12, 2009 5:15 am
by ned23
Quote, originally posted by agksimon »I received a Curt Hitch 12228 towing hitch after being told by their customer service that it would fit my 2009 AWD Vibe. I installed it, but the hitch was touching the muffler and at low rpm, made lots of noise. I had same problem with aftermarket hitch. I bought a couple of large hose clamps and cut an old piece of tire sidwall and clamped it in. Completely silent now.
Posted: Tue May 12, 2009 6:03 am
by Caretaker
The Drawtite model fits any model Vibe perfectly. As long as the holes are not filled with dirt and grime due to Pontiac not puting plugs over the 6 holes, the thing installs in minutes and doesn't rub against a thing. I put it on my 03 and 09.
Re: Hold Off Buying Towing Hitch for 2009 Vibe/Matrix (Caretaker)
Posted: Tue May 12, 2009 6:19 am
by ned23
Quote, originally posted by Caretaker »The Drawtite model fits any model Vibe perfectly. As long as the holes are not filled with dirt and grime due to Pontiac not puting plugs over the 6 holes, the thing installs in minutes and doesn't rub against a thing. I put it on my 03 and 09.Good info. I may buy a new hitch soon anyway. The hitch I have on my '09 now was transferred from my 2004 Vibe.
