				Bubble on side wall
				Posted: Wed Apr 23, 2008 10:37 am
				by Scootman!
				I was driving down a pot hole filled dirt road the other day and when I stopped I noticed that a small bubble (size of a nickel) was on the transition area between the side wall and the tread.  Will this cause a blow out for sure or do I have some time to replace the tire?
				Posted: Wed Apr 23, 2008 10:55 am
				by tnpartsguy
				Don't drive on it if you can avoid it. An actual bubble means the tire's skin is damaged internally, and being where it is, it could blow out really easy.
				Re:  (tnpartsguy)
				Posted: Wed Apr 23, 2008 11:00 am
				by Scootman!
				Maybe I should have said that it is raised in a half small somewhat like a bubble form.....  ....it does not look too terrrible but I guess it's time to replace it then.  These tires are only a few months old too, oh well thankfully I get a huge discount on tires.
				Posted: Wed Apr 23, 2008 11:44 am
				by lovemyraffe
				Replace it asap!  It will blow out.
				Re:  (lovemyraffe)
				Posted: Wed Apr 23, 2008 8:41 pm
				by Raven
				What kind of tires?
				Re:  (Raven)
				Posted: Wed Apr 23, 2008 9:16 pm
				by Kamikaze
				It's called a ply-seperation...It could be small... I've seen them where there's multiple little bubbles... but regardless if it's 1 or 10 of them... it means that the integrity of your tire has been compromised and could blow out at any time...
				Re: Bubble on side wall (Scootman!)
				Posted: Wed Apr 23, 2008 10:08 pm
				by ColonelPanic
				Had that happen to one of my tires too...  got it replaced as soon as I saw that bubble, not something you want to mess around with.
				Posted: Thu Apr 24, 2008 1:48 am
				by VIBEwithanO
				Like ColenelPanic I had a bubble myself once (on my last car). Unlike him, I didn't get it changed (I was poor and didn't think it'd be a big deal).  Two days later it blew out hard core right as I was getting on the freeway.  I'm so glad it did it before, since a blow out at higher speeds is a bad deal.  Change is asap.
				Re:  (VIBEwithanO)
				Posted: Thu Apr 24, 2008 3:25 am
				by 4X4CHICHI
				I just had to replace a tire that this happened to. It blew out. It was a rear tire though, calm as far as blowouts go.
				Re:  (4X4CHICHI)
				Posted: Thu Apr 24, 2008 3:31 am
				by NibCrom
				Pop it like a zit, your call will be fine.I'm just kidding, don't listen to me.
				Re:  (Raven)
				Posted: Thu Apr 24, 2008 8:35 am
				by Scootman!
				It is a Bridgestone Potenza G-OO9 which I'll probably replace with a Fuzion ZRi or something comparable.
