Vibe 2004 AC compressor relay
Posted: Tue Apr 22, 2008 2:49 am
by ozziegarzon
Does anyone know where the AC compressor relay is located for a 2004 vibeOzzie ...
Re: Vibe 2004 AC compressor relay (ozziegarzon)
Posted: Tue Apr 22, 2008 7:19 am
welcome to genvibethe ac clutch relay is in the underhood fuse block. It is the one that is farthest to the front and closest to the battery, enigmatically labelled "M/G CLT" on the inside of the cover
Re: Vibe 2004 AC compressor relay (joatmon)
Posted: Tue Apr 22, 2008 11:51 pm
by ozziegarzon
Joatmon,Thank you for your help. I'll see if I can test the relay now that you said were to look. Ozzie..
Posted: Wed Apr 23, 2008 9:50 pm
by ozziegarzon
I swaped the compressor relay with the horn relay but the compressor clutch still did not engaged. Ozzie ...
