Supercharger grinds
Posted: Sun Mar 30, 2008 3:08 am
by 4azdmunky
So i started up the car yesterday and the supercharger sounded like it had rocks in it. I searched and think that it might be the bearings. Anyone know where i can get some technical specifications in .pdf? I'm looking for information that relates to supercharger oil filling. My neighbor told me he saw some smoke coming from my car last week, i'm thinking something leaked, and the oil drained out. Anyone have this problem?
Re: Supercharger grinds (4azdmunky)
Posted: Sun Mar 30, 2008 4:52 am
by Raven
Sounds like rebuild time, too late for oil.
Posted: Sun Mar 30, 2008 5:14 am
by northvibe
how many miles are on it?Could be the screws touching each other or the snout needs the new puck thing and oil.
Re: (northvibe)
Posted: Sun Mar 30, 2008 5:33 am
by 4azdmunky
It has less than 10000 miles on it since it was installed end of November. What is the puck thing?
Re: (northvibe)
Posted: Sun Mar 30, 2008 5:35 am
by 4azdmunky
it does sound like its coming from where the screws are, so about dead center of the SC.How dangerous is it to drive with it like this? should I pull it out immediatly?
Posted: Sun Mar 30, 2008 6:45 am
by northvibe
HA finally found it, here check this thread out.
http://www.9thgencorolla.com/f...41602the screws spin so close if something got in there or they arent workign properly they could rub and make noise. if you say the noise is from the DEAD center of the SC then its something to do with the screws and you need to take it off the block and see if something is broken in there.
Re: (northvibe)
Posted: Sun Mar 30, 2008 7:56 am
by kevera
It sounds like your coupler is going.It might be a good idea to open her up and check the condition of the oil and the coupler itself.On side note,it's not a tiny bit of chattering when it's cold,and goes away when warm is it.
Re: (kevera)
Posted: Sun Mar 30, 2008 9:51 am
by 4azdmunky
Quote, originally posted by kevera »It sounds like your coupler is going.It might be a good idea to open her up and check the condition of the oil and the coupler itself.On side note,it's not a tiny bit of chattering when it's cold,and goes away when warm is it.Not sure, I havn't driven it since it started making noise so it hasn't warmed up. If it goes away when warm, what would it be? And anyone know where to get a SC repaired or where to buy parts for these things?
Posted: Sun Mar 30, 2008 10:33 am
by northvibe
from what i hear Magnuson makes these and they can be contacted for parts and repair.
Re: (4azdmunky)
Posted: Sun Mar 30, 2008 7:47 pm
by kevera
Judging by your answer,it never sounded like that before.Are you sure it's from the s/c,because when my belt tensioner went I swore something was wrong with the s/c.Just make sure first before you spend your money.Did you see any signs of an oil leak?This place also rebuilds s/c's,and so does magnuson.
http://www.psesuperchargers.com/
Posted: Sun Mar 30, 2008 10:53 pm
by northvibe
Yeah I agree ^ take off the SC and spin the pulley by hand to see if its the screws making the noise or the snout, but also check around the engine to see if its something else.
Re: (kevera)
Posted: Mon Mar 31, 2008 9:51 am
by 4azdmunky
Re: (northvibe)
Posted: Mon Mar 31, 2008 9:54 am
by 4azdmunky
Quote, originally posted by northvibe »Yeah I agree ^ take off the SC and spin the pulley by hand to see if its the screws making the noise or the snout, but also check around the engine to see if its something else.oh yeah, when I took the belt off and hand spun the SC it made the same sound. I got in touch with Magnuson today, they do warranty work on the SC's and since its 5 months old, it might be handled under warranty...sweet!
Re: (4azdmunky)
Posted: Mon Mar 31, 2008 10:16 am
by northvibe
Quote, originally posted by 4azdmunky »oh yeah, when I took the belt off and hand spun the SC it made the same sound. I got in touch with Magnuson today, they do warranty work on the SC's and since its 5 months old, it might be handled under warranty...sweet!Bad to hear about the noise..but sounds like the screws are rubbing. BUT sweet to hear its only 5months old and maybe covered! It should be I would think if its that young a sc and you bought it new.
Re: (northvibe)
Posted: Mon Mar 31, 2008 12:15 pm
by 4azdmunky
It was bought in November brand new in a sealed box, installed in the beginning of December by a local Toyota shop. The only thing I can think of is that because it is installed on a 05, and I'm running water injection, and the hydrogen cell, that the warranty might not be honored.
Posted: Mon Mar 31, 2008 12:58 pm
by northvibe
if you can make your car look stock.....with the sc I would recommend it. They may frown upon tho mods and say that caused it. Where does your water injection inject to? cai or into the SC itself?
Re: (northvibe)
Posted: Mon Mar 31, 2008 1:12 pm
by 4azdmunky
Quote, originally posted by northvibe »if you can make your car look stock.....with the sc I would recommend it. They may frown upon tho mods and say that caused it. Where does your water injection inject to? cai or into the SC itself?its mounted to the CAI. I'm assuming that I'll need to take the SC off and mail it in for repair.
Posted: Mon Mar 31, 2008 1:58 pm
by northvibe
depends if you take it to toyota/gm to get looked at or are sending the SC in to toyota or magnuson. If you take it to toyota/gm i would recommend installing the stock air box, otherwise they could blame your cai, as the instructions say to not use the cai, only the stock air box.
Re: (northvibe)
Posted: Mon Mar 31, 2008 10:52 pm
by DiveNut
X1
Re: (4azdmunky)
Posted: Tue Apr 01, 2008 5:05 am
by Petrucci914
I dunno. Mine would always make some mechanical noise because, well, it is a mechanical unit. No major grinding or anything, just the sounds of gears turning and whatnot.
Re: (Petrucci914)
Posted: Tue Apr 01, 2008 5:08 am
by kevera
His coupler is done,but the good thing is we will experience the same in the future-wuhoo!But the new style coupler lasts longer than the original ones in ours.
Re: (kevera)
Posted: Tue Apr 01, 2008 5:11 am
by Petrucci914
Don't remind me. I'll cry.
Re: (northvibe)
Posted: Wed Apr 02, 2008 11:50 am
by 4azdmunky
