Airbag Light Issue
Posted: Sat Mar 29, 2008 6:23 pm
by thebeansegg
My airbag light on the dashboard says the "passenger" airbag is off. This happened after I suspect the Vibe got tired of my passenger (beeping) seatbelt sensor kept going off due to me setting my laptop on the seat.I am now scared the airbag wont deploy for the passenger. how do I reset it?
Re: Airbag Light Issue (thebeansegg)
Posted: Sat Mar 29, 2008 6:54 pm
by darcmater
from what I have read, it says of if there is weight on the seat but not enough for it to need to deploy, it says on if there is weight on the seat over 80lbs I think and it says nothing if it detects no weight on the seat. Not sure if that helps but might explain it.
Re: Airbag Light Issue (darcmater)
Posted: Sun Mar 30, 2008 11:20 am
Quote, originally posted by darcmater »from what I have read, it says of if there is weight on the seat but not enough for it to need to deploy, it says on if there is weight on the seat over 80lbs I think and it says nothing if it detects no weight on the seat. Not sure if that helps but might explain it.Correct.OFF = weight detected, but not enough weight to permit airbag deployment.ON = weight detected, equal to or above threshold necessary to enable deploymentBLANK = no weight detected
