seafoam?
Posted: Thu Mar 06, 2008 7:34 am
by Twizted-Vibe
i just bought a can of seafoam to clean out my engine. ive used this on other cars easily and got awsome results. Right now my gas milage iss 260-300 to a tank which is terrible. i figured this may jelp some and also free up some power. On other cars i just leave the motor on and slowly pour it in the throttle body till i start seein smoke from the exhaust then leave it sit.When i tried it on this car, i cant get the car to stay running without the intake. when i remove the intake, the car stalls!Has nayone else used this? how you do it?
Re: seafoam? (Twizted-Vibe)
Posted: Thu Mar 06, 2008 10:15 am
by Twizted-Vibe
nvm.........got it!
Posted: Sat Mar 08, 2008 4:16 am
by KEYTECHNIQUES
Whats better then Seafoam is the GM top cylinder cleaner.
Posted: Sat Mar 08, 2008 8:13 am
by djb383
Seafoam is good stuff.................just pour it into the tank and go.
Re: seafoam? (djb383)
Posted: Fri Mar 14, 2008 3:58 am
by ProtonXX
1Injector cleaner kinda has the same effect as seafoam when i poured it in my cylinders directly
Posted: Fri Mar 14, 2008 4:28 am
by djb383
Remember, whatever you pour directly into the intake will not also clean the injectors. The cleaning solution must flow through the injector(s) in order to clean them.
Posted: Sun Mar 16, 2008 6:51 am
by 1zzfe_808
so how exactly do you "pour" it into the intake?
Re: (1zzfe_808)
Posted: Sun Mar 16, 2008 11:04 am
by djb383
I believe cleaners are usually "poured" into carbureted engines, down the carb. On EFI engines, the cleaner can be drawn/sucked into the intake thru the brake booster vacuum hose. Again, this method will not clean the injectors on EFI..........adding the cleaner to the fuel tank will.
