Creak noice
Posted: Mon Feb 25, 2008 10:23 am
by VforVIBE
I've noticed recently, when I turn the wheel at low speeds, the steering column creaks. Anyone know what's going on or how to fix it? Edit: and I didn't spell noise correctly.
Posted: Mon Feb 25, 2008 10:25 am
by northvibe
maybe it needs some lubrication at the joint part? do you know if its from the column or in the engine bay?
Re: (northvibe)
Posted: Mon Feb 25, 2008 10:28 am
by VforVIBE
Quote, originally posted by northvibe »maybe it needs some lubrication at the joint part? do you know if its from the column or in the engine bay? It might be in the engine bay, it sounds kinda distant.
Posted: Mon Feb 25, 2008 11:02 am
by WaveAction
it should be in the engine bay on the drivers side, most likely need a flashlight to see it, it's farther down and probably underneath the airbox tube that runs from the box to the throttle body..you might even have to go underneath the car to get at it
Re: Creek noice (VforVIBE)
Posted: Mon Feb 25, 2008 12:02 pm
by millster
Quote, originally posted by VforVIBE »Edit: and I didn't spell noise correctly. Fixed that for ya... oh and it would be "creak" as well, but who's counting?
Re: Creak noice (millster)
Posted: Mon Feb 25, 2008 12:35 pm
by VforVIBE
Quote, originally posted by millster »Fixed that for ya... oh and it would be "creak" as well, but who's counting? At least Creek is a word... even if it is the wrong one.
Re: Creak noice (VforVIBE)
Posted: Wed Feb 27, 2008 1:36 am
by VforVIBE
Anything else?
Posted: Wed Feb 27, 2008 1:40 am
by NibCrom
Did you check your power steering fluid?Is it possible it's something entirely different, like the brakes?
Re: Creak noice (NibCrom)
Posted: Wed Feb 27, 2008 1:42 am
by VforVIBE
Quote, originally posted by NibCrom »Did you check your power steering fluid?no, I'll have to do thatQuote, originally posted by NibCrom »Is it possible it's something entirely different, like the brakes?Nah, it's definitely has to do with turning the wheel.
Posted: Wed Mar 05, 2008 10:13 am
by ramenboy...
hey v, can't help you, only to say that probably something needs lubrication. sorry,but, i also wanted to say that if you were on the south side of chicago, then there would be no problem with 'noice'as in 'ey. i got some noice over der by da steering wheel'good luck
