Threaded Bolt Holes under right front of front seat
Posted: Tue Jan 22, 2008 11:07 am
by asburydan
I found 2 threaded bolt holes into the pan of the car under the front area of the front seat (on the raised area the seat sits on. My Vibe is '05 Base. Can anyone tell me what those holes are or could be for. I am attaching photos from two angles. Thanks.
Re: Threaded Bolt Holes under right front of front seat (asburydan)
Posted: Tue Jan 22, 2008 11:12 am
by asburydan
Sorry, the photos didn't attach. The two holes are about 2" apart.
Posted: Tue Jan 22, 2008 11:14 am
by asburydan
Here is the other photo. It worked when I didn't think it was doing so. Learned something.
Posted: Tue Jan 22, 2008 11:51 am
by northvibe
i wonder if those are for the amp on the moons and toons package.....
Posted: Tue Jan 22, 2008 12:33 pm
by asburydan
My car had the moons and toons package when I got it last month with 34,500K . Other ideas?
Posted: Tue Jan 22, 2008 7:10 pm
Driver side is power inverter, passenger is M&T amp. Those are the only two things you'd find under the front seats.
Re: (ragingfish)
Posted: Tue Jan 22, 2008 9:23 pm
by Kamikaze
Only thing I could think of is if those are pre drilled from the factory for the amp for the Voltz (right hand drive so the amp would be on the left side)Just a guess....
Posted: Tue Jan 22, 2008 11:11 pm
the thread title says the holes are under the right front of front seat. This pic of yours shows the holes and a floormat hook So, the holes are under the right front of the driver's side seat? If my '03 has those bolt holes, the carpet is not cut away like it is in yoursMaybe they are for the external CD changer that came with the factory navigation head unit. EDIT, no, the external CD changer with the NAV system goes under the passenger seat, replacing the M&T amp.
Posted: Wed Jan 23, 2008 12:49 am
by asburydan
Yes, the photo is taken at an angle showing floor mat hooks and the bar to move seat is above holes.
Re: Threaded Bolt Holes under right front of front seat (joatmon)
Posted: Wed Jan 23, 2008 1:13 am
by scherry2
just a question?is the front section of the floorpan exclusively vibe? it could be the front floorpan section of the Corolla and Vibe are interchangeable.In our plant the Chevy floor pan and GMC floor pan are the same sheetmetal but different locations for various things to bolt down to. just a guess though.
Posted: Wed Jan 23, 2008 6:09 am
by asburydan
Another good idea. Thanks for your help. It is a curiosity to me, and I happened to find the bolt holes when I was doing a good cleaning.
Posted: Wed Jan 23, 2008 8:16 am
by keithvibe
they are there for you to ask questions about them
Re: Threaded Bolt Holes under right front of front seat (keithvibe)
Posted: Wed Jan 23, 2008 9:34 am
by Raven
That's where the strap for the nitrous bottle attaches if you order the Drag Pack option.
Re: Threaded Bolt Holes under right front of front seat (Raven)
Posted: Tue Jan 29, 2008 1:17 pm
by MRCN RCE
Quote, originally posted by Raven »That's where the strap for the nitrous bottle attaches if you order the Drag Pack option.yep. too bad that wasn't available for the california vibes honestly i have no clue what those could be for... hmm
