Fixing Old Engine
Posted: Wed Dec 05, 2007 1:36 am
by ProtonXX
Is it possible to upgrade to a lightweight flywheel on a automatic?Light weight pistons & Parts...where where :DExhaust rattles after I put it back together. Its between the header/midpipe.Why
Re: Fixing Old Engine (ProtonXX)
Posted: Wed Dec 05, 2007 4:27 am
by Sublimewind
Quote, originally posted by ProtonXX »Is it possible to upgrade to a lightweight flywheel on a automatic?Light weight pistons & Parts...where where :DExhaust rattles after I put it back together. Its between the header/midpipe.Why No flywheel on an auto... you are thinking torque converter, which in essence is bolted to the "flywheel" as in a large round steel plate with gear teath cut on the outside, but no mating surface for the clutch... Lightweight pistons and such.... for what, it's a Vibe it was never ment for speed... They ARE out there... http://monkeywrenchracing.com/....htmlThe rattle is prolly a lose heat shield....
Re: Fixing Old Engine (Sublimewind)
Posted: Wed Dec 05, 2007 5:23 am
by Petrucci914
Quote, originally posted by Sublimewind »Lightweight pistons and such.... for what, it's a Vibe it was never ment for speed... Don't listen to him. He's a Subie Fanboy .
Re: Fixing Old Engine (Petrucci914)
Posted: Wed Dec 05, 2007 5:39 am
by Petrucci914
LevelTen does the most Tranny work for our Vibe. MWR also has a Torque Converter replacement.
