2003 Vibe GT - Coolant
Posted: Fri Nov 02, 2007 12:59 am
by Mo411
My thermostat has been sticking this week here in Michigan so I need to install new one and Coolant. Anyone experience issues or have preferences with a type of coolant. And is the stock Thermostat ok to use as the replacement. With all the different Coolants just wanted a recommendation. Thanks all
Re: 2003 Vibe GT - Coolant (Mo411)
Posted: Sat Nov 03, 2007 12:31 pm
by VivaVibe
Most people recommend the Toyota Red or Pink coolant available at a Toyota dealership. I think the stock thermostat should be sufficient.
Re: 2003 Vibe GT - Coolant (VivaVibe)
Posted: Wed Nov 14, 2007 4:17 am
by robdog
I put the Prestone stuff in, twice now and it works just fine.
Posted: Sun Nov 18, 2007 5:02 am
by jasonvibe
there is a true life time coolant by Peak. They call it Global $13/gal. It is compatible with all. Plus they warranty your cooling system if you document ithat it was flushed before you changed it to theirs. It's YELLOW. So it takes on the color of anything other coolant in there. I don't recommend Dexcool. Unless you absolutely change it before their 5 year recommendation. The original stuff is PINK Toyata long life. Orange is Dexcool. Don't let anyone tell you different.
Re: 2003 Vibe GT - Coolant (robdog)
Posted: Sun Nov 18, 2007 7:29 am
by djb383
Quote, originally posted by robdog »I put the Prestone stuff in, twice now and it works just fine.+1. Virtually all coolants now state on the bottle, 'safe for all metals and compatible with all brands and colors of coolants.
Re: (jasonvibe)
Posted: Sun Nov 18, 2007 11:51 am
by jake75
Quote, originally posted by jasonvibe »there is a true life time coolant by Peak. They call it Global $13/gal. It is compatible with all. Plus they warranty your cooling system if you document ithat it was flushed before you changed it to theirs. It's YELLOW. So it takes on the color of anything other coolant in there. I don't recommend Dexcool. Unless you absolutely change it before their 5 year recommendation. The original stuff is PINK Toyata long life. Orange is Dexcool. Don't let anyone tell you different.I have a 2003 and was told it was Dexcool - but if that were true I sort of questioned why the owner's manual said to replace every 24 months/30,000 miles whichever comes first. It looked orange to me. Under "what to use" the manual said "1/2 clean drinkable water and 1/2 coolant that meets GM Specification 1825-M with a completet coolant flush and refill."
