Transmission Cooler
Posted: Thu Oct 04, 2007 3:06 am
by quicksilver
Anyone have any advice on where to shop for one of these for a 2004 2WD Vibe?Also, maybe some tips on installation?Thanks!
Posted: Thu Oct 04, 2007 4:11 am
by northvibe
i got mine from summit racing.
Re: Transmission Cooler (quicksilver)
Posted: Thu Oct 04, 2007 4:37 am
search is your friend.start at
http://forums.genvibe.com/zerothread?id=23452 and see where that takes you
Re: Transmission Cooler (joatmon)
Posted: Thu Oct 04, 2007 5:46 am
by quicksilver
Yes, I already checked out that post, and the limited others, thank you though.
Posted: Thu Oct 04, 2007 7:17 am
by 02csnow
You could always check Ebay.Tip- Watch out for the tranny fluid and save every last drop
Re: Transmission Cooler (02csnow)
Posted: Thu Oct 04, 2007 7:21 am
by kevera
Ebay or summit racing are good places.If you work fast,you only drink a little.
Re: Transmission Cooler (kevera)
Posted: Thu Oct 04, 2007 8:42 am
by djb383
Yep, less than 1/2 qt., IIRC. I bought a qt. at the Toyota dealer before I started.
Posted: Thu Oct 04, 2007 11:51 am
by ajflan
Ok I hope this is not a stupid question, but what is the point of a tranny cooler on a car that is making 130hp? (I hope that there is a good reason because I'm running out of things to do...)
Re: (ajflan)
Posted: Thu Oct 04, 2007 12:16 pm
by 02csnow
A tranny cooler is mainly for a vehicle that has a SC or Turbo, due to all the force and high temps in the tranny. But can also be used on a stock engine if the driver is heavy on it or does alot of highway miles.
Re: (02csnow)
Posted: Thu Oct 04, 2007 12:31 pm
by ajflan
Wouldn't highway miles be easier on the trans because it is not shifting as much?
Re: (ajflan)
Posted: Thu Oct 04, 2007 12:39 pm
by blue_can
In general you need a tranny cooler if the impellor in the torque converter is turning much faster than the turbine. In this situation a lot of the engine’s output power is dissipated in the fluid and it really heats up. The most extreme condition is when doing a stall test on the transmission – you cannot do that for more than about 5 secs at a time. In normal use you can heat up the fluid by doing full throttle starts, towing or driving up steep hills. Once the TCC has applied there should be much less heat generated in the fluidUnless you do these things or live in a very hot climate a cooler should not be necessary. You can test how hot the transmission gets by using a temp measuring strip on the oil pan. It will record the highest temp reached by the transmission. You get them from most transmission parts stores for a few $.
Re: (ajflan)
Posted: Thu Oct 04, 2007 12:41 pm
by blue_can
Quote, originally posted by ajflan »Wouldn't highway miles be easier on the trans because it is not shifting as much? Yes, the TCC should normally be applied on the highway so the coupling should be mechanical at that point and so there should be much less heat generated.
Posted: Thu Oct 04, 2007 4:48 pm
by AKLGT
Hayden tranny coolers. universal and can be found on ebay for about $50 shipped.
Posted: Thu Oct 04, 2007 11:46 pm
by quicksilver
Sweet, that sounds affordable, easy to install eh? Btw, I'm looking at transmission coolers because I've been towing a good deal of weight lately and I want to protect my Vibe as much as I can I went from a V8 4x4 Jeep Grand Cherokee Limited to the Vibe, and I'm impressed with how much more I like this vehicle
Posted: Fri Oct 05, 2007 2:11 am
by AKLGT
you will never go wrong with a tranny cooler! and yes, very easy to install.
Re: (AKLGT)
Posted: Fri Oct 05, 2007 2:28 pm
by Lancer
Quote, originally posted by AKLGT »Hayden tranny coolers. universal and can be found on ebay for about $50 shipped. Got mine at Advanced Auto for $30. No shipping costs! But total for bigger zip ties, tranny fluid, and some other stuff (tools I didn't have) was around $50.
Re: (Lancer)
Posted: Fri Oct 05, 2007 10:35 pm
by zionzr2
I have seen tranny coolers avaliable for sale at U-Hual. I dont know how much or if they are any good, but they do sell them.
Posted: Sat Oct 06, 2007 11:02 am
by AKLGT
there are two types of tranny coolers. you want the serpentine one (i believe that's what it's called).
