First CEL
Posted: Tue Sep 18, 2007 1:01 am
by kunkstyle
Hit my first CEL at approx 23,500 km (15,000 mi) - it came in shortly after the start of my drive last week - unplugged the battery and it went away. Came in again this week shortly after the start of the drive to work. Taking it to the dealer tonight to see what the code is.- - - edit - - - Just realized that this is probably in the wrong thread...
Re: First CEL (kunkstyle)
Posted: Tue Sep 18, 2007 3:31 am
by Ninja_Logan
i just got mine about a month ago, im being lazy and havent gotten the codes pulled yet but im sure its due to the intake i put in but i have about 24,000 and had around 23,000 when it first hit.
Posted: Tue Sep 18, 2007 3:53 am
by kunkstyle
Fortunately this happened before I installed the intake. It won't be in until the 21st of the month. Had it come in after, that's probably what I would have chalked it up to.
Re: (kunkstyle)
Posted: Tue Sep 18, 2007 12:21 pm
by kunkstyle
Here's what GM said, and I quote:"Found code set in history #P0133. Checked with GM, they are aware of the problem, no known fix yet. Cleared code, took for test drive. Code didn't set again. Customer to bring up next appointment if sees light come back on."Anybody else had this code?
Re: (kunkstyle)
Posted: Tue Sep 18, 2007 12:38 pm
by Raven
PO133- O2 sensor circuit slow response(bank 1 sensor 1)This would be a problem with the first O2 sensor, the one on the exhaust manifold. It's an easy fix, especially under warranty.
Re: (Sunny)
Posted: Tue Sep 18, 2007 11:50 pm
by kunkstyle
Hrm. Wonder why they wouldn't have picked that up. What are my options at this point, just to take it to another dealer?
Re: (kunkstyle)
Posted: Wed Sep 19, 2007 8:48 am
by Raven
Wait and see if the CEL comes back on and either return to the same dealer and demand something to be done or go to another dealer.
Posted: Thu Sep 20, 2007 11:47 am
by Lancer
And do it BEFORE your warrenty expires. Cause after that happens all kinds of things just start falling apart.
Re: First CEL (Lancer)
Posted: Thu Sep 27, 2007 1:07 am
by kunkstyle
Update - So the CEL came on again, (about 3 times - I reset it by unplugging the battery, but just got tired of it after a while...) at which point I took it back down to the dealer. Talked to someone who actually had an answer for me. It's a "set in history" code, and the computer is unable to clear it even though the issue no longer exists (or never did). So it just keeps popping back up. Apparently GM is working on an update for the computer to fix the problem, which should be out by mid-late october.
