On the way!
Posted: Sun Sep 02, 2007 4:23 am
by 02csnow
Well I have ordered a oil catch resevoir and a tranny cooler. The tranny cooler is a tube style with fins. It is dual pass, with inner and outer coolers. They should be here by next weekend. I hoping that I am able to install them quickly. I also have some rolls of vinyl coming in. Red ultra metallic and gloss black. I have a few plans for them. I will definitely post some pics when I am all done.
Posted: Sun Sep 02, 2007 4:26 am
by northvibe
which oil catch can? I was thinking of getting the greddy one....FYI on the tranny cooler. Its a PITA to get the stock clamp/lines off.. Ive had my tranny cooler installed for a year but never hooked up because i cant get the stock ones off...I should try again...
Re: (northvibe)
Posted: Sun Sep 02, 2007 4:32 am
by 02csnow
I just got a universal one off of ebay. I dont plan on using the lines that come with. Gonna get some other lines from the auto parts store.http://cgi.ebay.com/ebaymotors...wItemI appreciate you letting me know about the lines. Now I know what I am looking at. I am just worried about fluids pouring on me.
Re: (northvibe)
Posted: Sun Sep 02, 2007 8:34 am
by damronjr
Quote, originally posted by northvibe »which oil catch can? I was thinking of getting the greddy one....FYI on the tranny cooler. Its a PITA to get the stock clamp/lines off.. Ive had my tranny cooler installed for a year but never hooked up because i cant get the stock ones off...I should try again...Ha, I never even got that far! Mine's still sitting in a box of mods I never got around to installing.
Re: (02csnow)
Posted: Sun Sep 02, 2007 8:39 am
by kevera
What's is the oil catch can for.Is there a lot of oil that gets blown back.
Re: (kevera)
Posted: Sun Sep 02, 2007 8:42 am
by 02csnow
It is to prevent oil from going into the intake manifold fom what I know. Overall your engine will last a little longer and posibly run better.A quote from a distributor"The oil catch tank mounts above your valve cover and ensures excess oil and dirt does not get inside your engine. This will ensure better mileage and better performance on your engine."
Posted: Sun Sep 02, 2007 11:22 am
by djb383
An oil catch can for the Vibe. Sounds like some serious marketing hype going on here. They're used on really serious 'race only' engines to keep oil off a track surface. With regard to the tranny cooler, I thought mounting the cooler itself was the tough part. For the lines just slide off the factory clamps/rubber hose and run rubber lines from the rad, to the cooler and back to the tranny.
Re: (djb383)
Posted: Sun Sep 02, 2007 2:24 pm
by northvibe
Quote, originally posted by djb383 »An oil catch can for the Vibe. Sounds like some serious marketing hype going on here. They're used on really serious 'race only' engines to keep oil off a track surface. With regard to the tranny cooler, I thought mounting the cooler itself was the tough part. For the lines just slide off the factory clamps/rubber hose and run rubber lines from the rad, to the cooler and back to the tranny. from what I know they catch the oil from going back into the IM and like o2csnow said should be better for the engine. BC has one and has capture lots of that nasty oil! :s euwThe tranny cooler wasnt a big deal with 2 people to mount...I for the life of me cannot get the mounts off the stock lines..they are freaking clamped on with the power of zeus!! serious, I had pliers and wrenches and 3 people try...I need a blow torch next i guess.
Re: (djb383)
Posted: Sun Sep 02, 2007 10:29 pm
by BlueCrush
My oil catch can fills up once a year and I empty it every spring. Mine holds about 16oz. of oil & gunk.
Re: (BlueCrush)
Posted: Mon Sep 03, 2007 12:12 am
by djb383
In a years time several gallons of water will pass through the intake/engine in the form of condensation (from the tank and gas pump) and absolutely no harm is done. 16 oz. of oil, in the form of an ultra fine vapor (blow-by), is no problem for any engine to digest, especially over a years time.
