Is it easy to change DRL Module?
Posted: Thu Aug 30, 2007 1:55 am
by josholiver1
I would like to change the DRL modual so that the turnsignals are on all the time in "bright mode" i found this..Universal DRL and i was wondering how you install these?
Re: Is it easy to change DRL Module? (josholiver1)
Posted: Thu Aug 30, 2007 2:27 am
by 98ex
It would be interesting to see that. Post pics if you do get it.I personally like thishttp://www.webelectricproducts...s.htmI might have to get this when I upgrade to LED lighting.
Posted: Thu Aug 30, 2007 5:08 am
by josholiver1
i wonder if its just plug and play for the DRL module..if it is i def want it
Re: (josholiver1)
Posted: Sun Sep 16, 2007 12:22 pm
by Digger
I have one of those. It worked great until the driver side bulb blew. It bubbled the inner lens in the process. Dealer replaced lens and called it a bulb malfunction. The pass side bulb blew today. it also bubbled the inner lens. We will see if the dealer will replace that one?? Need I tell you I also removed the DRL unit from the car today. I have used the same unit on other cars with out issue. I think the small area in the blinker lens is the issue. All in all I would not recommend it for the vibe. the guy that runs that site is great and a great guy to deal with.
Re: (Digger)
Posted: Mon Sep 17, 2007 10:48 am
by Digger
The dealer asked no ?. new lens on order. Love those guys
