06 vibe A/C, cuts out as its turned up!?
Posted: Wed Aug 15, 2007 11:46 am
by hellbender
So I turn up the AC as always, AC goes off..., turn it off and down, then back on, low fan, then it works. turn it up, it cuts off. wait.... start from the low settings again, i get it going full blast fine.... any ideas? don't know if it will persist, just happened...thanks folks
Re: 06 vibe A/C, cuts out as its turned up!? (hellbender)
Posted: Wed Aug 15, 2007 12:24 pm
by ColonelPanic
Is it the blower motor itself not working at certain positions on the dial? If so, that's probably the blower motor resistor. When they die, they'll fail open to the highest blower setting.If it's the actual A/C compressor shutting off, that's something different...
Re: 06 vibe A/C, cuts out as its turned up!? (ColonelPanic)
Posted: Wed Aug 15, 2007 7:58 pm
by Raven
Warranty?
Posted: Thu Aug 16, 2007 8:12 am
by harryyiii
Probably a low charge. There is usually a low pressure cutout switch which disables the compressor. If there is a slow leak, it will eventually stop completely.
Posted: Thu Aug 16, 2007 11:14 pm
by 98ex
If it is anything like the problem that faced the 03-04 Matrix, it is a relay. When the relay that controlled the AC Clutch got warm, it would overheat and shut down and then start up causiong the compressor to shut down and start up.
Posted: Fri Sep 21, 2007 10:02 am
by bull77
Just ran into a similiar issue tonight. Fan only works on HI - I can hear it but nothing blows out on LOW/MED - A/C or defrost..What gives??
Posted: Fri Sep 21, 2007 10:08 am
by WaveAction
in your case bull it would be the blower resister..atleast i believe it is..had something like that happen in my sunfire..the 2 lower speeds didnt work but u can hear the blower but nothing comes out..dont know where they are in the vibe but they're easy to do in a sunfire
Posted: Fri Sep 21, 2007 10:16 am
by bull77
Thanks!! I'm about as mechnical as a toddler so I'll make a stop into the dealer tomorrow.... 4k until 60k warranty is up
