Passenger side NO seatbelt un-realing
Posted: Wed Aug 08, 2007 11:49 am
by viper
I can't pull the front pass. seat belt out, how does the pillar trim panel comes off?
Posted: Wed Aug 08, 2007 12:03 pm
by viper
I meant un-reeling
Re: Passenger side NO seatbelt un-realing (viper)
Posted: Wed Aug 08, 2007 6:41 pm
I haven't done it, but found this in a headliner removal thread:Quote, originally posted by VibeForWinter »The Upper center pillar trim must come off. Remove the front and rear door sills, and then the lower trim (these pieces all just pull off). Pop the cover off the upper seat belt anchor, and remove the bolt holding the seat belt on, then you can pull the upper center trim panel.good to see you finally posting, sorry it's for a problem. hope it's an easy fix, let us know what you find in there
Re: Passenger side NO seatbelt un-realing (joatmon)
Posted: Wed Aug 08, 2007 10:33 pm
by Whelan
Don't pull fast
Re: Passenger side NO seatbelt un-realing (Whelan)
Posted: Thu Aug 09, 2007 8:47 am
by viper
Yep, my first post and sorry to say for assistance. I hardly use the car but someone brough the belt to my attention. Thanks 4 the advice.
Posted: Thu Aug 09, 2007 9:24 am
by scherry2
something like that should be covered under the warranty.
Re: Passenger side NO seatbelt un-realing (scherry2)
Posted: Mon Aug 13, 2007 7:00 am
by viper
The FIX/B] is, I found a piece 2x2" of mastic covered plastic wound/stuck to the belt w/in the reel. That removed the belt would reel freely. To re-attach the mouldings I found you need to pull the rubber gasket away first and press in last.I think the plastic covered a hole somewhere to keep out moisture.
