Reset Error Codes
Posted: Fri Jul 27, 2007 4:54 am
by Creslyn
Can anyone tell me how to reset the error codes on a 2003 Vibe? I tried unhooking battery after 10 min or so it still had not reset.
Re: Reset Error Codes (Creslyn)
Posted: Fri Jul 27, 2007 4:56 am
by 02csnow
Usually unhooking the battery to reset the computer normally works. You may want to go to a local auto store like Autozone or Advanced Auto Parts and have them reset it for you.
Posted: Fri Jul 27, 2007 5:35 am
by kevera
It might mean you have a problem,get the code read.
Re: Reset Error Codes (kevera)
Posted: Fri Jul 27, 2007 5:50 am
by satur9
you unhooked the negative terminal right? shouldve worked. your code is still pending if it didnt. get it checked soon.
Posted: Fri Jul 27, 2007 10:23 pm
by Sublimewind
If you care not to have the code read, disconnect the negative terminal on the batt and press the break pedal for a little while, or leave one of the doors open for a little bit... The bulbs will drain the system down...
Posted: Fri Jul 27, 2007 11:54 pm
by zionzr2
you can also reset it with a ScanGaugeII
