ignition timing scangauge favor.
Posted: Thu Jul 19, 2007 9:15 am
by satur9
can someone with a scan gauge do me a favor and check wot ignition timing. youll need to floor it foor about 2 to 3 seconds to stabilize the reading.
Re: ignition timing scangauge favor. (satur9)
Posted: Tue Jul 24, 2007 2:16 am
by ProtonXX
22 ign usually. On a bad day I seen 17.13-19 ign at idle32-29 ign cruising at 70mphThese numbers are up from when I switched to 5w20 oil
Re: ignition timing scangauge favor. (ProtonXX)
Posted: Tue Jul 24, 2007 5:54 am
by satur9
yeah mines usually 23. i was trying to see if the scangauge picked up advanced timing(unichip). it seems that it only reads stock signal (emailed scangauge) . thanks though.
Posted: Thu Jul 26, 2007 12:10 am
by ZubenElGenubi
At Idle: 14-15At 40 mph: 28At 65 mph: 37-38
Re: ignition timing scangauge favor. (ZubenElGenubi)
Posted: Thu Jul 26, 2007 11:44 am
by Digger
what is better low or high #? and what does it mean
Re: ignition timing scangauge favor. (Digger)
Posted: Fri Jul 27, 2007 6:07 am
by satur9
hard to answer since the numbers are all relative. gas, airtemp, air flow, rpm, vehicle, location, lots of things. i was just seeing if my wot readings were similiar to others. at wot all things being equal a lower number than around 23 MIGHT mean timing is retarded and your making less power.ignition timing is when the spark occurs (in degrees) during a piston stroke of the engine relative to top dead center (i think).you dont want the spark to occur to early or too late. but even im not sure how the numbers actually correlate. but it is kind of useful to notice a change from normal operating parameters
