What year Vibes have the sun visors that extend?
Posted: Thu Feb 22, 2007 2:26 pm
by BlueCrush
I need to find some and replace mine so I can get the sun out of my eyes while driving. Thanks!
Posted: Thu Feb 22, 2007 2:28 pm
by ragingfish
i believe it was 2004+
Re: (ragingfish)
Posted: Thu Feb 22, 2007 2:32 pm
by BlueCrush
Thanks Ragin'. I also found this thread after searching a little more:
http://forums.genvibe.com/zerothread?id=12946
Posted: Thu Feb 22, 2007 3:12 pm
by northvibe
I have a 2004 and the sun visors from my knowledge...dont extend..........but maybe i should double check...
Re: (northvibe)
Posted: Thu Feb 22, 2007 9:52 pm
by BlueCrush
If you have side air bags you won't have them. If you don't have side airbag then you should have them
Re: (BlueCrush)
Posted: Fri Feb 23, 2007 1:11 am
by kevera
I remember reading this a few years back.I forgot I even had these,thanks for reminding me.
Re: (kevera)
Posted: Fri Feb 23, 2007 1:16 am
by Vibr8tr
Quote, originally posted by northvibe »I have a 2004 and the sun visors from my knowledge...dont extend..........but maybe i should double check...Same here. I have a2004, and NO side airbags, and NO extending Visors. Do you mean they just will slide over, or do you mena that they should have the little plastic peice that comes out and makes it longer?
Re: (Vibr8tr)
Posted: Fri Feb 23, 2007 1:36 am
by BlueCrush
They are suppose to just slide out on the rail, the whole visor.
Re: (BlueCrush)
Posted: Fri Feb 23, 2007 1:44 am
by Vibr8tr
ok, maybe mine do that. I know one does, but I can't remember if it's the Vibe or the Lancer. I will check afte work to verify
Re: (Vibr8tr)
Posted: Fri Feb 23, 2007 7:03 am
by keithvibe
06 with out side air bags..and I have them.
Re: What year Vibes have the sun visors that extend? (BlueCrush)
Posted: Fri Feb 23, 2007 7:07 am
by VivaVibe
I have an 04 base with side airbags and my visors DO extend, although they advise not to do it when forward, only while turned to the side window. There's really not much room to the rearview mirror while positioned in front.
Re: What year Vibes have the sun visors that extend? (VivaVibe)
Posted: Fri Feb 23, 2007 9:44 am
by kevera
I have an 04 and they don't extend.Are they suppose to pull down or are they able to slide to cover the side window?
Posted: Fri Feb 23, 2007 9:47 am
by ColonelPanic
Quote, originally posted by VivaVibe »I have an 04 base with side airbags and my visors DO extend, although they advise not to do it when forward, only while turned to the side window. There's really not much room to the rearview mirror while positioned in front.I wonder if it's just the '05+ with the curtains that don't have the extensions? I can see where the curtain air bags would interfere with the extending visors, but maybe the ones from '04 that didn't have the curtains would be ok even if extended.
Re: What year Vibes have the sun visors that extend? (ColonelPanic)
Posted: Fri Feb 23, 2007 9:14 pm
by TRDman
I can verify at least the first part of your statement. My '05 with curtains and side airbags does not have them. With the information VivaVibe gave, what you said makes sense.
Re: What year Vibes have the sun visors that extend? (TRDman)
Posted: Sat Feb 24, 2007 1:19 am
by mcgusto82
my 04 with out side bags DID extend.
Posted: Sat Mar 24, 2007 9:51 am
by jsimon63
I'll be Hornswaggled! My 04 and 06 vibes both have them! I was flippin' through Genvibe for some good reading and found this subject. Had to run out and check! Thanks guys! Learn somethin' new everyday!
Re: (jsimon63)
Posted: Sat Mar 24, 2007 10:56 am
by Vibr8tr
I too checked, and it has it, and I have an 04. So I am guessing they all had it. Good concept, but I have never used it
