80,000 Miles And I Havent Changed My Belt ..YET
Posted: Tue Jan 23, 2007 10:59 am
by VibeTronic
Should I Change My Belt NOw ..Even Though It Shows No Signs Of Breakage? My Belt Tensioner Is Making Noise Though..
Posted: Tue Jan 23, 2007 1:58 pm
by CAN-AWD-VIBE
No cracks? or nics after that long... must be a record.you are going to have the belt off when you change the tensioner.... might as well swap it out now.Or leave it til it shows signs of "breakage"but then you will need a tow truck.whatever turns you on.
Posted: Tue Jan 23, 2007 10:39 pm
by zionzr2
I would say switch it and hold on to it as a spare in case you do get a bad belt in the future.
Re: (zionzr2)
Posted: Tue Jan 23, 2007 11:49 pm
by VibeTronic
thnx...i may just go on ahead and buy a new belt..but iis it hard to get on and off...?
Re: 80,000 Miles And I Havent Changed My Belt ..YET (VibeTronic)
Posted: Thu Feb 15, 2007 9:20 am
by shryocdj
are you guys talking timing belt?
Re: 80,000 Miles And I Havent Changed My Belt ..YET (shryocdj)
Posted: Thu Feb 15, 2007 10:22 am
no, the serpentine accessory drive belt. Vibes/matrixes have timing chains, which last a lot longer than timing belts.http://forums.genvibe.com/zerothread?id=16476 has JohnC's tips on changing the belt.
Re: 80,000 Miles And I Havent Changed My Belt ..YET (joatmon)
Posted: Thu Feb 15, 2007 10:34 am
by shryocdj
really good to know thanks muchand as far as the tensioner, is that something that routinely gets replaced also? or is it just due to his making noise?
Posted: Thu Feb 15, 2007 10:57 am
by 2002sportside
The serpentine belt tensioner only needs to be replaced if it develops a problem.As for the belt change... not hard at all. Should take 5-10 minutes to do.
