Key won't open door
Posted: Tue Jan 16, 2007 10:58 pm
by chadmt
My remote to my 2003 Vibe is working fine, but I actually tried to use my key to manually open my doors and it would not open either the driver, passenger door, or hatch. I tried my regular and spare key. Anybody have any ideas? Do I just need to apply some WD40? I had not tried to use my key in quite a while.
Re: Key won't open door (chadmt)
Posted: Tue Jan 16, 2007 11:14 pm
by BlueCrush
Welcome to GenVibe! WD-40 should work. Let it soak for a while then try it again. Re-apply if needed. Just be prepared for it to spray back out of the keyhole at you, so don't put your face down there when you spray. Or better yet throw on some safety glasses/goggles. You eyes will thank you later. Also, make sure you have something ready to wipe it off the paint, asap. Good Luck! Let us know how it works.
Posted: Tue Jan 16, 2007 11:31 pm
Has that key ever opened the door?
Re: Key won't open door (joatmon)
Posted: Tue Jan 16, 2007 11:40 pm
by BlueCrush
Quote, originally posted by joatmon »Has that key ever opened the door? Oh, didn't catch that! Yeah, maybe the locks were changed out at some point if it doesn't work in any of them.
Posted: Tue Jan 16, 2007 11:53 pm
by Baltovibe
Quote, originally posted by chadmt »I had not tried to use my key in quite a while.Quote, originally posted by joatmon »Has that key ever opened the door?I originally thought the same thing, but he did imply that he had used the key before. And, apparently the same key can be used on the ignition.I have a car with remote that I use all the time. When I tried to use the key on the door locks and trunk recently, they were locked up. I guess the tumblers get stiff from lack of use. Solution was liquid graphite used for locks.
Re: Key won't open door (Baltovibe)
Posted: Wed Jan 17, 2007 12:32 am
by redlava
Are you sure you have the right car?Hey it happened to me once.Don't make faces.
Posted: Wed Jan 17, 2007 12:49 am
by chadmt
Yeah... it has opened the door in the past. Am just so reliant on the remote that I rarely have used the key to open the door. But you never know if the remote battery might decide to give up when you are in the middle of Timbuktu. I will try the graphite!
Posted: Wed Jan 17, 2007 1:26 am
locks stiff from lack of use is a lot better than someone getting a Vibe and having the ignition lock keyed differently than the doors, which would prompt the question "which locks were replaced, and why?".Welcome to genvibe!
