Tien s tech springs
Posted: Sun Nov 12, 2006 12:12 am
by kevera
HI all,I was wondering if the tien s tech springs that are for the Trix will fit the vibe.I can only see the fitment for the toyota and not the pontiac.Also,Do you need a camber kit for these springs.Thanks
Re: Tien s tech springs (kevera)
Posted: Sun Nov 12, 2006 1:47 am
by CAN-AWD-VIBE
they will... no camber kit neededi have some for sale if you would likesay $150 CAN + shippingbut they are in Canada so no dutyI bought them before I found out they were not good for my AWD but great for all the others.
Posted: Sun Nov 12, 2006 1:48 am
by northvibe
They do fit the vibe, but make sure you get ones that fit trix xr or base = vibe basetrix xrs = vibe gttrix awd = vibe awdand no you do not need a camber kit, just get an alignment done after the springs are installed and youve driven for about 2 weeks.(i forgot if the springs are different for each model of vibe/trix )
Re: (northvibe)
Posted: Sun Nov 12, 2006 2:45 am
by kevera
Thanks northvibe,I know it was a noob question,but just wanted to make sure,Best Regards.
Re: (kevera)
Posted: Sun Nov 12, 2006 3:45 am
by Mavrik
you may need a camber kit to adjust the rear alignment if its out. But thats a "maybe" I know I did but I know ppl who didn't.
Posted: Sun Nov 12, 2006 12:21 pm
by LUVROK
How is the camber adjusted in the rear?
Re: (LUVROK)
Posted: Sun Nov 12, 2006 12:30 pm
by Mavrik
its non-adjustable which is why you'll need the kits.The kit looks like a disc thats hollow in the middle. You have the alignment machine tell you what setting to turn the disc to and then you put that disc between the hub and the axle assy and rebolt it back on. This sets the camber. I'll see if I can get pics of mine to show what I mean.
Posted: Tue Nov 14, 2006 12:17 am
by ramenboy...
hey kevera,what they said. in fact, the s-techs that were installed on my vibe a couple weeks ago listed Part: S.TECHModel: MATRIX 03+on the labelthe car feels greatenjoy the ride
Re: (ramenboy...)
Posted: Tue Nov 14, 2006 7:12 am
by kevera
Ramenboy-did you use the camber kit,and does the vibe feel tighter in turns with a little less body roll,cuz that p#$s me off,plus say no to wheel gap.
Posted: Tue Nov 14, 2006 7:14 am
by kevera
So,Should I get the camber kit or not-front or rear.I am cunfused cuz some say yes,some say no,Help........
Posted: Tue Nov 14, 2006 9:28 am
by Mavrik
the front is adjustable, no kit required. The rear however is non-adjustable unless you buy a kit. But no point in buying the kit until you see if the rear will even be out. It may not be out. I know mine was after lowering the car. But for the $12 the kit was from NAPA I'd hold off until you get the alignment inspected at least. Thats my advice.
Re: (kevera)
Posted: Wed Nov 15, 2006 12:03 am
by ramenboy...
hey keveramavrik made a good point. but i have no camber kit. didn't need it. maybe depends on your wheel/tire comboyes, a very noticeable difference in cornering. negligible body roll. definiteley a nice tight ride.
Posted: Sat Nov 18, 2006 2:52 am
by DopeVibeGT
Just got my Stechs from Neverenough! Thanks Brad. Very fast, too!
