empty spots in under dash fuse panel
Posted: Sat Nov 04, 2006 4:07 am
by satur9
does anybody know if these can be used.are they always hot or ignition powered. i was thinking about adding fuse taps in them . it looks like it has terminals on boths sides of the empty fuse spot. so i dont know if the wire is dead ended somewhere .i could always use a blown fuse tap. so just the hot side where the aux tap is remains hot. but i just wanted to get other opinions see if anyone else has done this. before i screw my back up messing around down there. also does anybody know which wire ( hopefully near the shifter)( 5 speed btw) turns on the reverse lights.
Re: empty spots in under dash fuse panel (satur9)
Posted: Sat Nov 04, 2006 4:52 am
the reverse light switch is on the tranny
Re: empty spots in under dash fuse panel (joatmon)
Posted: Sat Nov 04, 2006 5:45 am
by satur9
do you have any idea where that wire or relay or whatever comes up into the car thats not all the way in the back by the lights
Posted: Sat Nov 04, 2006 7:11 am
here's the diagram. Looks like no relay
Attached files 023bl.pdf (23 KB)
Posted: Sat Nov 04, 2006 7:14 am
That diagram above says the wires come in via juntion "J3" which from page 6 of this PDF looks like it is behind the glove box somewhere
Attached files parts.pdf (289 KB)
Posted: Sat Nov 04, 2006 8:12 am
by satur9
thanks
Posted: Sat Nov 04, 2006 8:31 am
so what are you up to, needing all this odd information and stuff?
Posted: Sun Nov 05, 2006 2:47 am
by satur9
i need power and a signal for revesrse. it should be obvious to someone like you.i asked about the fuses cause i already got a lot of stuff on my radio and lighters circuits.if you cant guess i'll have pics by tues.
Posted: Sun Nov 05, 2006 5:48 am
I have a hunch, and it is not to hook up a reverse beeper so you can pretend to be a GT
Posted: Sun Nov 05, 2006 6:44 am
by zionzr2
could it be a reverse seeing camera?
Re: (zionzr2)
Posted: Mon Nov 06, 2006 10:32 am
by satur9
ding ding ding, we have a winner. theres a white harness with a black/red wire behind the glovebox. thats the reverse wire.(found in another post.) its all wired up but the cams not mounted so i'll get pictures in the daylight tommorow.
Posted: Sun Jan 04, 2009 6:38 am
by ChewieDaWookiee
Have you ever found out what the empty spots in the under dash fuse panel were hot, engine running, or bogus?
Posted: Mon Jan 05, 2009 4:46 am
by satur9
sorry never found out.i just tapped the radio and reverse wire and moved some other stuff.
Re: (satur9)
Posted: Mon Jan 05, 2009 5:52 am
by ChewieDaWookiee
Thanks. For getting back to me though.
Re: (ChewieDaWookiee)
Posted: Mon Jan 05, 2009 5:56 am
by keithvibe
some of the open spots are constant hot, some are igg. on.Use a tester light like I did to figure out which ones are which. All are usable though.
