OBX 2 pulley set
Posted: Fri Oct 06, 2006 1:13 pm
by vibe Freak
I just got these on today and WOW they are great. The little Vibe is really coming together nicely. I was supposed to leave it stock. Next will be the rear sway bar.
Re: OBX 2 pulley set (vibe Freak)
Posted: Sat Oct 07, 2006 12:39 am
by CAN-AWD-VIBE
Congrats!!!Those are the alt and crank pulleys right? Were they a PITA to install?leave it stock... good luck with that welcome to the addiction that is modifying
Re: OBX 2 pulley set (CAN-AWD-VIBE)
Posted: Sat Oct 07, 2006 12:28 pm
by vibe Freak
I had my mechanic do it for $45. He will be putting a new tensioner pulley and belt on for no charge on Monday.
Posted: Wed Oct 11, 2006 11:05 am
by CanadianTim
Does the original belt still work? What improvements did you notice?Thanks
Re: (CanadianTim)
Posted: Wed Oct 11, 2006 2:05 pm
by vibe Freak
Yes it still works, because the alternator pulley is bigger than stock. As fare as what it does way better throttle response. This is only for the 1zz motor.
Posted: Wed Oct 11, 2006 11:06 pm
by CanadianTim
Good to hear it freed the motor up a bit. Do you have an Auto or 5 speed? Have you had any issues or heard of any issues with battery charging or AC operation? I suspect if the pulley ratios have that big an impact without any downside, that Toyota would be using them stock as these should increase fuel economy as well. I run nearly 100% highway so I've considered these since charging should not be an issue with my driving and the extra power is always a plus.
Re: (CanadianTim)
Posted: Thu Oct 12, 2006 3:37 am
by vibe Freak
I have a auto base vibe. I have had them on for a week now with no problems at all.
Re: (vibe Freak)
Posted: Fri Oct 13, 2006 5:14 am
by vibe Freak
Guys just make sure you change out the front main seal when you do the pulleys. Because you may get a slit oil leek if you don't. Ask me how I know
Re: (vibe Freak)
Posted: Fri Oct 27, 2006 8:54 am
by vibe Freak
New seal is in and the leek is all gone.
Posted: Fri Oct 27, 2006 10:14 am
by DopeVibeGT
Leave it stock? Within the first month of having mine, I had the CAI and catback on. LOL They beg to be modded.
Re: (vibe Freak)
Posted: Fri Oct 27, 2006 10:15 am
by DopeVibeGT
Does this apply to the VVTL-i too?
Re: (DopeVibeGT)
Posted: Sat Oct 28, 2006 3:17 am
by vibe Freak
This only applies to the basic Vibe. This is only for the 1zz application.
Re: (vibe Freak)
Posted: Mon Oct 30, 2006 10:41 pm
by 1fstramand1slovibe
Where did you find those pulleys realy could use a good site. just got the ARE stage 2 intake and a vibrant strut bar on mine this weekend. already had a silverline canister and custom piping from the cat back with the resonators cut off.anyway i would really appreciate some help finding parts so far the only places ive found them is
http://www.autopartswarehouse.com and
http://www.performancecenter.com. any others out there
Re: (1fstramand1slovibe)
Posted: Mon Oct 30, 2006 10:54 pm
by Raven
http://www.neverenoughauto.com...d=899 He is an excellent supplier. A Genvibe member too.
Re: (Sunny)
Posted: Mon Oct 30, 2006 11:05 pm
thanks great looking sites.
Posted: Mon Oct 30, 2006 11:48 pm
by northvibe
i read on another site...9thgencorolla i think that they have new aluminum T70xxx or something which is lighter and stronger than the current T60xxx made ones. just a fyi
Re: (northvibe)
Posted: Tue Oct 31, 2006 2:07 am
where did you find those obx pulleys?
Posted: Wed Nov 01, 2006 12:46 pm
by vibe Freak
I looked under celica pulleys on eBay. They are $95.00 plus 15 for shipping. i am running the stock size belt because the alternator pulley is bigger. They work great, but I would change the seal when you do the pulleys.
Re: (vibe Freak)
Posted: Thu Nov 02, 2006 1:53 am
by Raven
What's up with the seal? Does it get damaged during the removal of the stock pulley and need replacing?
Re: (Sunny)
Posted: Thu Nov 02, 2006 3:22 am
yeah im kinda wondering about that myself.
Re: (vibe Freak)
Posted: Fri Nov 03, 2006 7:28 am
by scherry2
Quote, originally posted by vibe Freak » i am running the stock size belt because the alternator pulley is bigger. is there a certain belt you need if only changing the crank pulley or will the tensioner take up the slack?
Re: (scherry2)
Posted: Fri Nov 03, 2006 8:30 am
by vibe Freak
The seal is so it will not leek. The old seal will be worn so a new one will be a nice tight fit. I had a little leek I had the seal replaced and no more leek. As fare as the belt I am really not shore.
